17253 Discussions
Can't launch the Modelsim-Altera Software
My OS is Windows 8 64 bit. I'm using Quartus II 13.1 Web Edition, and Modelsim 10.1d.
My path in EDA Tools is set to "C:\altera\13.1\modelsim_ase\win32aloem", when I go Tools > Run Similation Tool > RTL Simulation; I get this Nativelink Error:
Can't launch the ModelSim-Altera software -- the path to the location of the executables for the ModelSim-Altera software were not specified or the executables were not found at specified path...
I can manually start it by the way.
Thank you
Baris Yakut
--- Quote Start ---
OK, this is a link to the licensed Modelsim-Altera. But what's the path to the ModelSim starter Edition?
--- Quote End ---
"modelsim_ase" is Model Sim Altera Starter Edition.
"C:\altera\13.1\modelsim_ase\win32aloem\" is the correctly location for the Starter Edition.
(and another +1 like to taquionbcn for posting the solution)
Thanks!!!!
thanks, it works!!
KHill
Okay, so far, in the Quartus window I'm selecting:
Assignments > Settings
Then in the pop-up window, the following category:
EDA Tool Settings > Simulation
Help, I don't see any place to insert a path to the simulator executable... The output directory is given though.
SSHRE2
You are looking into wrong path.
You should go to Tools> Options>EDA Tool Options
And then insert the valid path.
Sumeet S.
bl6
May I know why my waveform unable to run? I changed the path to C:\altera\13.1\modelsim_ase\win32aloem\.
My version is ModelSim Starter Edition 13.1
Nandu
I am getting the same as " Can't launch modelsim altera simulation software --make sure the software is properly installed and the environment variable LM_LICENSE FILE or MGLS_LICENSE FILE points to correct lincense file.. Check the NativeLink log file", in Ubuntu 22.04,please guide me to solve this
nico29
Hello, I know its been a long time but can you tell me how you solved this problem. Im also in ubuntu 22.04 and Im having the same error. Thanks
HubertG
HubertG
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum case, did not reach us as intended. As a result, we have a backlog of cases that we are currently working through.
We are glad to hear that with the power of community, the solution has been discovered ! Bravo !
Once again sorry in advance and thanks a lot for everybody's hardwork
Best Regards
Hubert
HubertG
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
