- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
We are working on Quartus Version : Quartus Prime Version 21.1.0 Build 169 03/24/2021 SC Pro Edition
Target Device: 1SG280HU2F50E2VG
Added "External Memory Interfaces Intel Stratix 10 FPGA IP" on Quartus Platform Designer.
Enabled preset filter: Stratix 10 GX H-Tile FPGA Development Kit with DDR4 HILO
Changed Memory -> Topology-> DQ width from 72 to 32 to change Avalon interface Data width to 256bits. This change has popped up below two Errors
Cannot place ALERT# in DQS group 8 since the group value is out of range
"DQS group of ALERT#" (MEM_DDR4_ALERT_N_DQS_GROUP) 8 is out of range: 0,1,2,3
Changed "ALERT# pin placement" from "I/O lane with DQSGroup" to "Automatically select a location"
Are these valid changes?
I still see below warning
Warning: emif_s10_0: The selected board is 'Stratix 10 GX H-Tile FPGA Development Kit with DDR4 HILO'. Ensure that a development kit preset is applied before generating the example design; do not modify the IP parameters. For verified development kit test results, the selected development kit preset text should be bolded in the Presets panel.
What is the action for this Warning?
Siva Kona
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
When you created the Quartus project, did you select that board in the New Project Wizard?
You made changes from the preset, so it's warning you that you made changes from that preset so the design may not work with the board you selected. If you're OK with this, you can ignore the warning.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi sstrell, Thanks for your reply.
Preset configuration of "Stratix 10 GX H-Tile FPGA Development Kit with DDR4 HILO" shows following Errors
emif_s10_0.ctrl_amm_0 Data width must be of power of two and between 8 and 4096
This is because the DQ width value 72 sets the Avalon MM Interface Data width as 576.
We have changed the DQ width from 72 to 32, to align the ctrl_amm_0 data width(256 bits) to the other modules in the system
This change resulted in following Errors during Generate HDL run.
Error: no such variable
Error: Generation stopped, 2 or more modules remaining
Error: qsys-generate failed with exit code 1: 2 Errors, 1 Warning
Error: SPD file was not generated: /nfs/site/disks/hpg_meu/snkona/22WW06_GyANN_FPGA/ip-gyann-fpga/s10gx/fpga_gdlj_onchipmem/qips/ip/gyann_fpga/gyann_fpga_emif_s10_0/gyann_fpga_emif_s10_0.spd
Error: Could not generate simulation scripts
Siva Kona
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi sstrell,
"Sync System infos" also did not change the behavior. Got same Errors as before.
Following is the snapshot of the messages around first Error
Siva Kona
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Don't even bother trying to generate if you have any red error messages. It will always fail.
If you're still seeing the power of 2 error, check whatever is connected on the other side. Something is mismatched or incorrect. It could be as simple as removing a connection and then adding the connection back in to refresh the system.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Siva Kona,
- Yes the change is valid.
Do you see any error message in the qsys?
What is the DQ pins per DQS group that you used?
Adzim
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Siva,
I have sent an email to you regarding to your request.
Please let me know if you not receive the email.
Adzim
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Update: Using the workaround from the KDB in the link below has solved the issue.
https://www.intel.com/content/www/us/en/support/programmable/articles/000087056.html
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
