17249 토론
Custom IP - Suspected Interface Problem
road_runner
초보자
2,109 조회수
The following attached files describe a binary-to-hex display code custom IP peripheral for Nios II. The top-level file  was selected as the bin_hex_interface file. I included the .tcl (as a .txt as the file upload system wouldn't support it), .v, and .c main files. To test, I simply used the hello_world_small sample from Eclipse and then wrote code that passes a value to that custom IP and reads it back. So, for example, passing a value of 0 into it would return 0x40 as this is the value needed to write 0 into the hex displays. Unfortunately, though, this is all I can return back, no matter what value I try to write to it. I don't know if there is something wrong with my interface, the basic module hardware logic should in theory be fine (I tested it by itself but that doesn't mean I didn't mess up somewhere and my tests didn't catch it), or the macro I'm using, but something somewhere isn't working right.  Please let me know what I'm doing wrong. Thanks in advance!
레이블 (1)
0 포인트
1 솔루션
road_runner
초보자
1,766 조회수
I apologize. I misread the documentation. Needed BOTH Verilog files to make it work. I fixed it. It's missing the byte-addressing for the architecture.
원본 게시물의 솔루션 보기
0 포인트
7 응답
wwanalim_intel
2,062 조회수
Greetings and welcome to Intel's forum.
Please give me some time to check on this issue and will get back to you with the update.
Thank you.
Fathulnaim
0 포인트
sstrell
명예로운 기여자 III
2,036 조회수
When you say "this is all I can return back", are you saying that 0 is the only value that works (or works correctly)?  Or are you saying that no matter what value you put in, you always get 0x40 out?
0 포인트
wwanalim_intel
2,015 조회수
I'm currently reviewing the attached design. Kindly grant me a bit more time to thoroughly examine it.
0 포인트
wwanalim_intel
1,986 조회수
Where do you get the custom IP design?
0 포인트
wwanalim_intel
1,900 조회수
Do you have any updates to share?
I would need your response to have a better understanding about the issue.
0 포인트
wwanalim_intel
1,861 조회수
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
0 포인트
road_runner
초보자
1,767 조회수
0 포인트
응답
