Error reading file
Hi I'm trying to read a text file which is basically many lines of 1s and 0s, e.g.
At the moment if I include the file I get the following error message when I try to compile:
Error (10170): Verilog HDL syntax error at data_file.txt(1) near text "1"; expecting an identifier, or "endmodule", or a parallel statement
and the cursor is on the first line of the added file. There are many bits in this file so I need to change the verilog method of reading I suppose, but I don't know how.
The syntax I'm trying to use is:
// include file (outside module description)
`include "C:\*path*\data_file.txt"
integer fileID;
initial begin
fileID = $fopen("data_file.txt", "r");
end
I have also tried to read it without the include line with:
fileID = $fopen("*path*data_file.txt", "r");
but then I get error message:
Error (10174): Verilog HDL Unsupported Feature error at datafile9.v(21): system function "$fopen" is not supported for synthesis
Any help would be very much appreciated.
what "include" statement means that replace the statement from the file.
what you did is compiling just numbers in VerilogHDL.
that doesn't make sense.
in term of $fopen case.
actually verilog-HDL does support $fopen.
but QuartusII does not support some case of Verilog rules.
how about that prepare file like that
`define MYNUMBER 32'h00FF00FF00FFFFF
and use the definition in your code.
fileID = `MYNUMBER;
does it help for you?
Hi, I am having the same issue with $fopen.
I am trying to read in an .rbf file and use the following snippet of code:
integer file;
file = $fopen("helper.rbf", "r");
and receive this error:
Error (10174): Verilog HDL Unsupported Feature error at testbench.v(40): system function "$fopen" is not supported for synthesis
I followed what you suggested by storing the file ID to a variable, but I also need to read in the file. Here is part of my code
integer char;
integer file = 32'h3C2718;
char = $fgetc(file);
I receive this error:
Error (10174): Verilog HDL Unsupported Feature error at testbench.v(40): system function "$fgetc" is not supported for synthesis
Note-I am doing simulation only. I compile using Processing->Start->Start Analysis & Elaboration
I am using Quartus II v16.0 on linux
Is there another method where I can read and write to a file?
I found what I was doing wrong, I need to use ModelSim to compile my testbench instead of quartus.
You may also use synthesis translate_off/on synthesis directive to tell quartus excude part of you source file from sythesis. Sometimes it's very usefull. http://quartushelp.altera.com/14.0/mergedprojects/hdl/vlog/vlog_file_dir_translate.htm
