17268 Discussions
Errors when trying to create 24 hr clock in Quartus II using VHDL
I am news to VHDL and trying to create a 24 hr clock with hours, minutes and seconds that outputs on the seven segment display but I am getting errors and have been unable to resolve them. Here is the code.
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity clocker is port (CLOCK_50: in std_logic; printer: in std_logic_vector(15 downto 0); enter: in std_logic_vector(3 downto 0); out1, out2, out3, out4, out5, out6, out7, out8 : out std_logic_vector(0 to 6)); end clocker; architecture Behavior of clocker is component ring port (dividor, divisor : in std_logic_vector(3 downto 0); clock2, reset, inner, outer : in std_logic_vector(3 downto 0); p: out std_logic_vector(3 downto 0)); end component; component printOut2 port( digit : in std_logic_vector(3 downto 0); print : out std_logic_vector(0 to 6)); end component; signal count: std_logic_vector(24 downto 0); signal h0, h1, m0, m1, s0, s1: std_logic_vector(3 downto 0); signal divh0: std_logic_vector(3 downto 0); signal sec0, sec1, min0, min1, hr0, hr1: std_logic; begin process(CLOCK_50) begin if (CLOCK_50'event and CLOCK_50 ='1') then count <= count + '1'; end if; end process; sec0 <= '1' when (count = 0) else '0'; secs0: ring port map ("0000", "1001", CLOCK_50, enter(3), '0', sec0, s0); sec1 <= '1' when (s0 = 9) and (sec0 = '1') else '0'; secs1: ring port map ("0000", "0101", CLOCK_50, enter(3), '0', sec1, s1); min0 <= '1' when (s1 = 5) and (sec1 = '1') else '0'; mins0: ring port map (printer(3 downto 0), "1001", CLOCK_50, enter(3), not enter(0), min0, m0); min1 <= '1' when (m0 = 9) and (min0 = '1') else '0'; mins1 : ring port map(printer(7 downto 4), "0101", CLOCK_50, enter(3), not enter(0), min1, m1); hr0 <= '1' when (m1 = 5) and (min1 = '1') else '0'; divh0 <= "0011" when (h1 = 2) else "1001"; hrs0: ring port map(printer(11 downto 8), divh0, CLOCK_50, enter(3), not enter(0), hr1, h0); hr1 <= '1' when (((h1 = 2) and (h0 = 3)) or (h0 = 9)) and (hr0 = '1') else '0'; hrs1 :ring port map (printer(15 downto 12), "0010", CLOCK_50, enter(3), not enter(0), hr1, h1); hrs1: ring port map (printer(15 downto 12), "0010", CLOCK_50, enter(3), not enter(0), hr1, h1); d7: printOut port map (h1, out8); d6: printOut port map (h0, out7); d5: printOut port map (m1, out6); d4: printOut port map (m0, out5); d3: printOut port map (s1, out4); d2: printOut port map (s0, out3); d1: printOut port map ("1111", out2); d0: printOut port map ("1111", out1); end Behavior; library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity ring is port (dividor, divisor : in std std_logic_vector(3 downto 0); clock2, reset, inner, outer : in std_logic_vector(3 downto 0); p: out std_logic_vector(3 downto 0)); end ring; architecture Behavior of ring is signal count2: std_logic_vector(3 downto 0); begin process(clock2) begin if (clock2 = '1' and clock2'event) then if (reset = '0') then count2 <= "0000"; elsif (inner = '1') then count2 <= dividor; elsif (outer = '1') then if (count2 = divisor) then count2 <= "0000"; else count2 <= count + '1'; end if; end if; end if; end process; p <= count2; end Behavior; library ieee; use ieee.std_logic_1164.all; entity printOut2 is port( digit : in std_logic_vector(3 downto 0); print : out std_logic_vector(0 to 6)); end printOut2; architecture Behavior of printOut2 is begin process(digit) begin case(digit) is when "0000" => print <= "0000001"; when "0001" => print <= "1001111"; when "0010" => print <= "0010010"; when "0011" => print <= "0000110"; when "0100" => print <= "1001100"; when "0101" => print <= "0100100"; when "0110" => print <= "1100000"; when "0111" => print <= "0001111"; when "1000" => print <= "0000000"; when "1001" => print <= "0001100"; when others => print <= "1111111"; end case; end process; end Behavior;
The errors I get are:
Error (10476): VHDL error at clocker.vhd(42): type of identifier "CLOCK_50" does not agree with its usage as "std_logic_vector" type
Error (10381): VHDL Type Mismatch error at clocker.vhd(42): indexed name returns a value whose type does not match "std_logic_vector", the type of the target expression
Error (10316): VHDL error at clocker.vhd(42): character ''0'' used but not declared for type "std_logic_vector"
Error (10476): VHDL error at clocker.vhd(42): type of identifier "sec0" does not agree with its usage as "std_logic_vector" type
Please tell me where I am going wrong. Thanks!
Your "ring" components only has std_logic_vector ports, but you are trying to connect a single bit clock to a 4 bit vector.
Did you mean to have the clock2 signal as a std_logic_vector?
