- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi All,
I am still a beginner to FPGAs, but I think I'm making good progress. I am able to simulate my own Verilog code in ModelSim-Altera and everything looks correct. However, when I try to simulate an Altera Megafunction (DCFIFO in this case) all of the outputs are always HiZ no matter what inputs I give. I have done a lot of searching but I haven't come across anything which solved my problem. All of the other threads I found usually conclude with "Add the libraries", but I have done that. The code compiles fine. I'm running the simulation with "vsim work.sync_fifo -L altera_mf" Output screenshot is attached. After looking into the generated code it seems like the Megawizard just generates wrappers. How do I get the actual internals to simulate? I also understand the during synthesis a lot of optimization happens. Outputs which are not depended on by the rest of the design get removed. But if I am simulating the module directly, this should not happen, correct? ThanksLink kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
From the attached waveform, it seems you have tied the FIFO reset signal to one. I think its reset signal is active-high; If so, drive it with '1', and after a few clock cycles drive it with '0'.
More over, issue some write request signals, so that something would be written into it.- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
What did you put in the testbench? It looks like there is nothing more than a clock and a reset stuck at 1
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Right now the test bench IS just a clock signal. I added in a reset to 1 in that screenshot just to try it out. Whether it is 1 or 0, the outputs are still HiZ. I also tried what msj suggested, which was drive reset to 1 for a few clocks, then drive to 0. Still no change.
I have also tried some write signals previously. Here's another screenshot. I think this should write 5 bytes of 8'b10101010 to the FIFO. Is this wrong?- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
have you actually connected the clock to the FIFO? how about the other signals?
Post the testbench code?- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
what is clock frequency? Are you simulating a post-place & route design or a pre-synthesis one?
you'd better post your code.- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I'll be totally honest with you, I was running commands directly in ModelSim just to experiement. That is probably a dumb thing to do. I wrote a test bench which produces the attached output.
`timescale 1ns / 100ps
module sync_fifo_tb ();
// Inputs to module
reg clk;
reg wrreq;
reg rdreq;
reg data;
reg sclr;
// Outputs from module
wire q;
wire usedw;
wire full;
wire empty;
// Instantiate device
sync_fifo U1(
.clock(clk),
.data(data),
.rdreq(rdreq),
.sclr(sclr),
.wrreq(wrreq),
.empty(empty),
.full(full),
.q(q),
.usedw(usedw)
// Clock setup
always
# 5 clk = ~clk;
// Initial setup
initial
begin
clk = 0;
sclr = 1;
wrreq = 0;
rdreq = 0;
data = 8'b10101010;
# 50 sclr = 0;
# 20 wrreq = 1;
@(posedge clk); // Wait 5 clocks
@(posedge clk);
@(posedge clk);
@(posedge clk);
@(posedge clk);
# 5 wrreq = 0;
end
endmodule
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I posted a test bench file, but that is awaiting moderation for some reason. In the meantime, I'm not entirely sure how to answer that question msj.
I am opening the Verilog files in a ModelSim project and compiling them there. I am then running the vsim command on the module itself. The module was generated using the Quartus II Megawizard. There is no code of my own, except for the test bench. I don't think this is a problem with code though. This problem is occurring for any of the generated megafunctions. Even when I try to simulate a PLL megafunction, which takes no inputs but a 50MHz clock, has HiZ outputs. I must be doing something else wrong, but I have no idea what it might be.- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
meanwhile, run simulator without optimization:
vsim -novopt work.sync_...- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
"vsim -novopt work.sync_fifo_tb -L altera_mf" produces no change. I even recompiled with -O0 first.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- I'll be totally honest with you, I was running commands directly in ModelSim just to experiement. That is probably a dumb thing to do. I wrote a test bench which produces the attached output. --- Quote End --- Ive unblocked all your posts - posting code with low post numbers requires moderation. No, that is a perfectly normal thing to do (and much better than running it from quartus). Have you compiled the sync_fifo block? where is the code for that?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I have added both the sync_fifo.v and sync_fifo_bb.v files, generated from the wizard, into my ModelSim project. They both compile fine, along with my test bench.
Here is the code for sync_fifo.v:// megafunction wizard: %FIFO%
// GENERATION: STANDARD
// VERSION: WM1.0
// MODULE: scfifo
// File Name: sync_fifo.v
// Megafunction Name(s):
// scfifo
// Simulation Library Files(s):
// THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE!
// 13.0.0 Build 156 04/24/2013 SJ Web Edition
//Copyright (C) 1991-2013 Altera Corporation
//Your use of Altera Corporation's design tools, logic functions
//and other software and tools, and its AMPP partner logic
//functions, and any output files from any of the foregoing
//(including device programming or simulation files), and any
//associated documentation or information are expressly subject
//to the terms and conditions of the Altera Program License
//Subscription Agreement, Altera MegaCore Function License
//Agreement, or other applicable license agreement, including,
//without limitation, that your use is for the sole purpose of
//programming logic devices manufactured by Altera and sold by
//Altera or its authorized distributors. Please refer to the
//applicable agreement for further details.
// synopsys translate_off
`timescale 1 ps / 1 ps
// synopsys translate_on
module sync_fifo (
clock,
data,
rdreq,
sclr,
wrreq,
empty,
full,
q,
usedw);
input clock;
input data;
input rdreq;
input sclr;
input wrreq;
output empty;
output full;
output q;
output usedw;
wire sub_wire0;
wire sub_wire1;
wire sub_wire2;
wire sub_wire3;
wire usedw = sub_wire0;
wire empty = sub_wire1;
wire full = sub_wire2;
wire q = sub_wire3;
scfifo scfifo_component (
.clock (clock),
.sclr (sclr),
.wrreq (wrreq),
.data (data),
.rdreq (rdreq),
.usedw (sub_wire0),
.empty (sub_wire1),
.full (sub_wire2),
.q (sub_wire3),
.aclr (),
.almost_empty (),
.almost_full ());
defparam
scfifo_component.add_ram_output_register = "OFF",
scfifo_component.intended_device_family = "Cyclone II",
scfifo_component.lpm_numwords = 2048,
scfifo_component.lpm_showahead = "OFF",
scfifo_component.lpm_type = "scfifo",
scfifo_component.lpm_width = 8,
scfifo_component.lpm_widthu = 11,
scfifo_component.overflow_checking = "ON",
scfifo_component.underflow_checking = "ON",
scfifo_component.use_eab = "ON";
endmodule
// CNX file retrieval info
// Retrieval info: PRIVATE: AlmostEmpty NUMERIC "0"
// Retrieval info: PRIVATE: AlmostEmptyThr NUMERIC "-1"
// Retrieval info: PRIVATE: AlmostFull NUMERIC "0"
// Retrieval info: PRIVATE: AlmostFullThr NUMERIC "-1"
// Retrieval info: PRIVATE: CLOCKS_ARE_SYNCHRONIZED NUMERIC "1"
// Retrieval info: PRIVATE: Clock NUMERIC "0"
// Retrieval info: PRIVATE: Depth NUMERIC "2048"
// Retrieval info: PRIVATE: Empty NUMERIC "1"
// Retrieval info: PRIVATE: Full NUMERIC "1"
// Retrieval info: PRIVATE: INTENDED_DEVICE_FAMILY STRING "Cyclone II"
// Retrieval info: PRIVATE: LE_BasedFIFO NUMERIC "0"
// Retrieval info: PRIVATE: LegacyRREQ NUMERIC "1"
// Retrieval info: PRIVATE: MAX_DEPTH_BY_9 NUMERIC "0"
// Retrieval info: PRIVATE: OVERFLOW_CHECKING NUMERIC "0"
// Retrieval info: PRIVATE: Optimize NUMERIC "0"
// Retrieval info: PRIVATE: RAM_BLOCK_TYPE NUMERIC "0"
// Retrieval info: PRIVATE: SYNTH_WRAPPER_GEN_POSTFIX STRING "0"
// Retrieval info: PRIVATE: UNDERFLOW_CHECKING NUMERIC "0"
// Retrieval info: PRIVATE: UsedW NUMERIC "1"
// Retrieval info: PRIVATE: Width NUMERIC "8"
// Retrieval info: PRIVATE: dc_aclr NUMERIC "0"
// Retrieval info: PRIVATE: diff_widths NUMERIC "0"
// Retrieval info: PRIVATE: msb_usedw NUMERIC "0"
// Retrieval info: PRIVATE: output_width NUMERIC "8"
// Retrieval info: PRIVATE: rsEmpty NUMERIC "1"
// Retrieval info: PRIVATE: rsFull NUMERIC "0"
// Retrieval info: PRIVATE: rsUsedW NUMERIC "0"
// Retrieval info: PRIVATE: sc_aclr NUMERIC "0"
// Retrieval info: PRIVATE: sc_sclr NUMERIC "1"
// Retrieval info: PRIVATE: wsEmpty NUMERIC "0"
// Retrieval info: PRIVATE: wsFull NUMERIC "1"
// Retrieval info: PRIVATE: wsUsedW NUMERIC "0"
// Retrieval info: LIBRARY: altera_mf altera_mf.altera_mf_components.all
// Retrieval info: CONSTANT: ADD_RAM_OUTPUT_REGISTER STRING "OFF"
// Retrieval info: CONSTANT: INTENDED_DEVICE_FAMILY STRING "Cyclone II"
// Retrieval info: CONSTANT: LPM_NUMWORDS NUMERIC "2048"
// Retrieval info: CONSTANT: LPM_SHOWAHEAD STRING "OFF"
// Retrieval info: CONSTANT: LPM_TYPE STRING "scfifo"
// Retrieval info: CONSTANT: LPM_WIDTH NUMERIC "8"
// Retrieval info: CONSTANT: LPM_WIDTHU NUMERIC "11"
// Retrieval info: CONSTANT: OVERFLOW_CHECKING STRING "ON"
// Retrieval info: CONSTANT: UNDERFLOW_CHECKING STRING "ON"
// Retrieval info: CONSTANT: USE_EAB STRING "ON"
// Retrieval info: USED_PORT: clock 0 0 0 0 INPUT NODEFVAL "clock"
// Retrieval info: USED_PORT: data 0 0 8 0 INPUT NODEFVAL "data"
// Retrieval info: USED_PORT: empty 0 0 0 0 OUTPUT NODEFVAL "empty"
// Retrieval info: USED_PORT: full 0 0 0 0 OUTPUT NODEFVAL "full"
// Retrieval info: USED_PORT: q 0 0 8 0 OUTPUT NODEFVAL "q"
// Retrieval info: USED_PORT: rdreq 0 0 0 0 INPUT NODEFVAL "rdreq"
// Retrieval info: USED_PORT: sclr 0 0 0 0 INPUT NODEFVAL "sclr"
// Retrieval info: USED_PORT: usedw 0 0 11 0 OUTPUT NODEFVAL "usedw"
// Retrieval info: USED_PORT: wrreq 0 0 0 0 INPUT NODEFVAL "wrreq"
// Retrieval info: CONNECT: @clock 0 0 0 0 clock 0 0 0 0
// Retrieval info: CONNECT: @data 0 0 8 0 data 0 0 8 0
// Retrieval info: CONNECT: @rdreq 0 0 0 0 rdreq 0 0 0 0
// Retrieval info: CONNECT: @sclr 0 0 0 0 sclr 0 0 0 0
// Retrieval info: CONNECT: @wrreq 0 0 0 0 wrreq 0 0 0 0
// Retrieval info: CONNECT: empty 0 0 0 0 @empty 0 0 0 0
// Retrieval info: CONNECT: full 0 0 0 0 @full 0 0 0 0
// Retrieval info: CONNECT: q 0 0 8 0 @q 0 0 8 0
// Retrieval info: CONNECT: usedw 0 0 11 0 @usedw 0 0 11 0
// Retrieval info: GEN_FILE: TYPE_NORMAL sync_fifo.v TRUE
// Retrieval info: GEN_FILE: TYPE_NORMAL sync_fifo.inc FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL sync_fifo.cmp FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL sync_fifo.bsf TRUE
// Retrieval info: GEN_FILE: TYPE_NORMAL sync_fifo_inst.v TRUE
// Retrieval info: GEN_FILE: TYPE_NORMAL sync_fifo_bb.v TRUE
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
The black box is no use to you - it is just there as a top level file for the interfaces - it has no functionality (hence black box). Are you simulating this file?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
No, I am simulating the sync_fifo.v file.
It appears that all this file does is instantiate and wire up an scfifo. Could it be that this file is missing from my project? I have no idea where to find it so I can add it and compile. But if that were the case, how would sync_fifo.v compile at all? e: Interestingly, if I remove the sync_fifo_bb.v file, I cannot start a simulation of sync_fifo.v. I get the error: vsim work.sync_fifo -L altera_mf# vsim -L altera_mf work.sync_fifo # Loading work.sync_fifo# ** Error: (vsim-10000) Z:/Altera_Projects/video_prototype/sync_fifo.v(83): Unresolved defparam reference to 'scfifo_component' in scfifo_component.add_ram_output_register.# # Region: /sync_fifo# ** Error: (vsim-10000) Z:/Altera_Projects/video_prototype/sync_fifo.v(84): Unresolved defparam reference to 'scfifo_component' in scfifo_component.intended_device_family.# # Region: /sync_fifo# ** Error: (vsim-10000) Z:/Altera_Projects/video_prototype/sync_fifo.v(85): Unresolved defparam reference to 'scfifo_component' in scfifo_component.lpm_numwords.# # Region: /sync_fifo# ** Error: (vsim-10000) Z:/Altera_Projects/video_prototype/sync_fifo.v(86): Unresolved defparam reference to 'scfifo_component' in scfifo_component.lpm_showahead.# # Region: /sync_fifo# ** Error: (vsim-10000) Z:/Altera_Projects/video_prototype/sync_fifo.v(87): Unresolved defparam reference to 'scfifo_component' in scfifo_component.lpm_type.# # Region: /sync_fifo# ** Error: (vsim-10000) Z:/Altera_Projects/video_prototype/sync_fifo.v(88): Unresolved defparam reference to 'scfifo_component' in scfifo_component.lpm_width.# # Region: /sync_fifo# ** Error: (vsim-10000) Z:/Altera_Projects/video_prototype/sync_fifo.v(89): Unresolved defparam reference to 'scfifo_component' in scfifo_component.lpm_widthu.# # Region: /sync_fifo# ** Error: (vsim-10000) Z:/Altera_Projects/video_prototype/sync_fifo.v(90): Unresolved defparam reference to 'scfifo_component' in scfifo_component.overflow_checking.# # Region: /sync_fifo# ** Error: (vsim-10000) Z:/Altera_Projects/video_prototype/sync_fifo.v(91): Unresolved defparam reference to 'scfifo_component' in scfifo_component.underflow_checking.# # Region: /sync_fifo# ** Error: (vsim-10000) Z:/Altera_Projects/video_prototype/sync_fifo.v(92): Unresolved defparam reference to 'scfifo_component' in scfifo_component.use_eab.# # Region: /sync_fifo- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
That implies it is using the sync_fifo_bb file as the reference for the sync_fifo - hence the Z outputs. It also now means you havent included the altera libraries properly.
Remove the _bb file from the project. This is only for copy/pasting into your code.- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I have removed it from the project. What do I need to do besides add the "-L altera_mf" to my vsim command? I thought ModelSim-Altera came with all the Altera libraries already installed. I see a huge list in the libraries pane, and altera_mf is definitely in there.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Oops, that should be:
vsim sync_fifo_tb -L altera_mf_ver- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
altera_mf is the vhdl library the verilog versions are all _ver
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Gah! Of course it is.
Thanks for all your help. It's working now! For future people: You have to also make sure you add the library to your modelsim.ini file in the project directory. My library section looks like this: [Library] others = $MODEL_TECH/../modelsim.ini ; Altera Primitive libraries ; ; VHDL Section ; ; ; Verilog Section ; altera_mf_ver = $MODEL_TECH/../altera/verilog/altera_mf- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I have very similar problem but I can't fix it yet. I see "U" on all outputs of my Fifo_x16. I generate the Fifo_x16 using Quartus Pro 18.1 and I use VHDL 2008. I think vsim doesn't use the right library for the simulation. Can you please tell me how to make it use the right library. I think Fifo_x16 is not part of the megafunction (mf).
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
