Finite State Machine..
Geehrter Beitragender II
2.789Aufrufe
i have problem here..
please help me out..
I'm designing a vending machine that accept only coins( 10 cent, 20 cent, and 50 cent)
A = 10 cent
B = 20 cent
C = 50 cent
the error still appear after simulation even i edit the coding several times.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY fsm1 is
PORT ( clk, rst : in std_logic;
A, B, C : in std_logic;
Z : out std_logic);
END fsm1;
ARCHITECTURE structural of fsm1 is
TYPE state is ( s0, s1, s2, s3, s4, s5, s6, s7 );
SIGNAL y : state;
BEGIN
fsm_transition: PROCESS ( clk, rst)
BEGIN
IF rst = '1' THEN y <= s0;
ELSIF clk'event and clk = '1' THEN
CASE y is
WHEN s0 => IF A = '1' THEN y <= s1;
ELSIF B = '1' THEN y <= s2;
ELSIF C = '1' THEN y <= s5;
ELSE y <= s0;
END IF;
WHEN s1 => IF A = '1' THEN y <= s2;
ELSIF B = '1' THEN y <= s3;
ELSIF C = '1' THEN y <= s6;
ELSE y <= s1;
END IF;
WHEN s2 => IF A = '1' THEN y <= s3;
ELSIF B = '1' THEN y <= s4;
ELSIF C = '1' THEN y <= s7;
ELSE y <= s2;
END IF;
WHEN s3 => IF A = '1' THEN y <= s4;
ELSIF B = '1' THEN y <= s5;
ELSIF C = '1' THEN y <=s7;
ELSE y <= s3;
END IF;
WHEN s4 => IF A = '1' THEN y <= s5;
ELSIF B = '1' THEN y <= s6;
ELSE y <= s4;
END IF;
WHEN s5 => IF A = '1' THEN y <= s6;
ELSIF B = '1' THEN y <= s7;
ELSE y <= s5;
END IF;
WHEN s6 => IF A = '1' THEN y <= s7;
ELSE y <= s6;
END IF;
END CASE;
END IF;
END PROCESS fsm_transition;
Z <= '1' WHEN y = s7 ELSE '0';
END structural;
4 Antworten
1.089Aufrufe
You didn't tell about the error at all. It's obvious, that the coin counter advances while any input is activated, this wouldn't work in real life of course. Also, a WHEN s7 =>
or WHEN OTHERS => case may be missing.
1.089Aufrufe
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off fsm1 -c fsm1 --generate_functional_sim_netlist
Warning: Using design file fsm1.vhd, which is not specified as a design file for the current project, but contains definitions for 2 design units and 1 entities in project
Info: Found design unit 1: fsm1-structural
Info: Found entity 1: fsm1
Info: Elaborating entity "fsm1" for the top level hierarchy
error (10313): vhdl case statement error at fsm1.vhd(19): case statement choices must cover all possible values of expression
error: can't elaborate top-level user hierarchy
error: quartus ii functional simulation netlist generation was unsuccessful. 2 errors, 1 warning
Info: Allocated 167 megabytes of memory during processing
Error: Processing ended: Mon May 05 09:35:49 2008
Error: Elapsed time: 00:00:02
1.089Aufrufe
tQ..
i got it..
:D
1.089Aufrufe
My requirement is that my computer program wants to use the information presented by Finite State Machine. For Example what are the states, actions, events and next states. How information of Finite State Machine can be presented before giving it as input to computer program?
My program will work as :
Read state and then according to events and actions determine next state. In short I want to implement State Transition Table.
I need help which data structure should be used?
Kindly Help me.
Asif Iqbal
Antworten
