17264 Discussions
Generating a design in platform designer
aleks555
I am trying to generate a design in the platform designer with just a clock module and HPS. I get the following message: Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Error during execution of "{C:/intelfpga_lite/20.11/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
followed by around 100 lines starting with the "Error: border: Error during execution of script generate_hps_sdram.tcl:"
Tried Quartus lite 20.1 and 20.1.1 but always the same error.
I saw that this error happens also in 18.1 (https://www.intel.com/content/www/us/en/support/programmable/articles/000080619.html) and it says it is planned to be fixed in future release. When/which version of quartus will that be?
sstrell
What is your target device and how do you have the memory interface set up with respect to the HPS in Platform Designer (PD)?  A screenshot of your PD system would be helpful.
The only device I can think of that would be SoC and supported in Lite would be Cyclone V.
aleks555
Yes, it is the Cyclone V (5CSEM). The design was originally implemented with Quartus 18 so it is a working solution (generating a new design with 20.1 doesn't work also).
aleks555
