17268 Discussions
Hi, Have been able to add the qsys ADC module to the project but on final compilation the flow summary reports 0/1 ADC blocks in use even after I have selected all ports ANA1IN1 to ADC1IN8 in the qsys window.
AKohl3
 From what i can tell the ADC module only needs a command to select which port to sample so how do i make pin assignments to confirm the ADC in use!
SreekumarR_G_Intel
Hello there ,
Here attached the screen shot and the modfied design file with ADC block utilization mentioned in the compliation report.
As of understood from the design you provided , quartus is optimizing the ADC block since it is no where used in the design.
In the modified design i instantiated the ADC input and clock as Input port which restrict the quartus to optimize the same.
Hope helps ,
Thank you ,
Sree
AKohl3
Looking forward to your reply!
Avdit
SreekumarR_G_Intel
can I know did you get a chance to figure it the issue ? if you still facing the issue kindly let me know ?
Thank you,
Sree
SreekumarR_G_Intel
sorry , didnt see your updated post ; Can I know you still facing the issue ?
Thank you ,
Sree
AKohl3
Yes Sree, I am still facing the same issue besides I have attached all files you requested in the past. Can you please provide an solution to the above attached project file as soon as possible?
SreekumarR_G_Intel
sorry, i didnt noticed your reply , can i know is that issue resolved ? kindly let me know if you looking for my design files still.
Apologize my delay in response.
SreekumarR_G_Intel
Hello , I thought i attached the file to you , Sorry looks i missed out, Can i know you still facing the same issue ? if yes , i will look at again .
AKohl3
I am still facing the same problem. I have been able to check the ADC input if I invoke the Jtag avalon adapter but if I use just the ADC control core the response data is stuck at zero. In the attached project I am trying a simple led blink check using the output of the ADC module. I would really appreciate a prompt reply.
SreekumarR_G_Intel
Hello there ,
Hope helps ,
Thank you ,
Sree
SreekumarR_G_Intel
hello ,
sorry , I completed missed that your case here.
can you let me know you still facing the same issue , if yes I can attach the design which another customer posted the same in fourm.
Thank you ,
Sree
