17267 Discussions
How to constraint min delay between LCELLs?
NuvKFC
Some asynchronous need to use LCELLs to generate pulses, like following example.
However, the delay of LCELLs is different on the difference FPGA device.
So, I use following constraints to constraint the min delay of LCELL.
But it doesn't work.
Thank you very much.
Ex.:
lcell dly1d (.out(y1), .in(A) );
lcell dly4d (.out(y), .in(y1) );
Constraints:
set_min_delay 5.0 -from [get_pins dly1d|combout] \
                                  -to      [get_pins dly4d|combout]
set_net_delay -min 5.0  -from [get_pins dly1d|combout] \
Nurina
Right so I don't think this constraint works on LCELLS alone. Because you would need a setup/hold relationship in the first place.
Which brings us back to using set_data_delay, which definitely should work on LCELL alone.
Since it isn't supported on Quartus II 13.1, I suggest you migrate to Quartus Standard 21.1 as this would have the set_data_delay.
On the other hand, you are using LCELL to generate a pulse to wake up the clocks right? Maybe you could consider using clock control IP: https://www.intel.com/content/dam/support/jp/ja/programmable/support-resources/bulk-container/pdfs/literature/ug/ug-altclkctrl.pdf
Nurina
NuvKFC
Hi Nurina
    Thank you, Nurina, very much.
OK. I  get it. Thank you very, very much. ^.^
NuvKFC
Hi Nurina
Sorry that I have a question.
Using set_min_delay need a setup/hold relationship on that path.
Why set_net_delay can't work on LCELLS?
Nurina
Just like set_max/min_delay, set_net_delay requires the path to have a setup/hold relationship (reg to reg path). So it doesn't go through comb logic.
Nurina
NuvKFC
Hi Nurina
OK, I get it. Thank you very, very much.
Nurina
No problem! I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution.
NuvKFC
Hi Nurina
OK. No problem! Thank you very, very much.
