Some asynchronous need to use LCELLs to generate pulses, like following example.
However, the delay of LCELLs is different on the difference FPGA device.
So, I use following constraints to constraint the min delay of LCELL.
But it doesn't work.
How to constraint min delay between LCELLs?
Thank you very much.
Ex.:
lcell dly1d (.out(y1), .in(A) );
lcell dly4d (.out(y), .in(y1) );
Constraints:
set_min_delay 5.0 -from [get_pins dly1d|combout] \
-to [get_pins dly4d|combout]
set_net_delay -min 5.0 -from [get_pins dly1d|combout] \
Right so I don't think this constraint works on LCELLS alone. Because you would need a setup/hold relationship in the first place.
Which brings us back to using set_data_delay, which definitely should work on LCELL alone.
Since it isn't supported on Quartus II 13.1, I suggest you migrate to Quartus Standard 21.1 as this would have the set_data_delay.
On the other hand, you are using LCELL to generate a pulse to wake up the clocks right? Maybe you could consider using clock control IP: https://www.intel.com/content/dam/support/jp/ja/programmable/support-resources/bulk-container/pdfs/literature/ug/ug-altclkctrl.pdf
Nurina
链接已复制
No problem! I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution.
