17266 Discussions
How to extract 1bit from a bus in a Block Diagram/Schematic File
Well, I'm new to quartus and I don't know if this is possible or not. i can handle it in verilog/vhdl but I wanted to know if this can be done in a block diagram file.
This is what I want to do: (Example)
I've implemented a lpm_add_sub as an 8 bit adder, how can I for example use bit 2 & 3 of the output as inputs of another gate?(I need to extract these 2 bits out of the output )
I hope what I've said is clear enough.
Thanks in advance.
Select the bus and type a name for the bus like: result[8..0]
Then, using the Orthogonal Node tool, create a line, select the line (signal) and type a name for the signal like: result[5]. This signal is the bit 5 of the bus result[8..0].
(Sorry for the bad english, i'm brazilian):)
Rodrigo Willians
--- Quote Start ---
Rodrigo Willians
--- Quote End ---
Thanks buddy! That's what I needed!
I, myself am from Iran!
Good and clear.
One principle: always name the wider bus first, then name the narrower bus accordingly.
By the way, I am Chinese.
--- Quote Start ---
Good and clear.
--- Quote End ---
Thankyou !
