Well, I'm new to quartus and I don't know if this is possible or not. i can handle it in verilog/vhdl but I wanted to know if this can be done in a block diagram file.
This is what I want to do: (Example) I've implemented a lpm_add_sub as an 8 bit adder, how can I for example use bit 2 & 3 of the output as inputs of another gate?(I need to extract these 2 bits out of the output ) I hope what I've said is clear enough. Thanks in advance.Link Copied
Select the bus and type a name for the bus like: result[8..0]
Then, using the Orthogonal Node tool, create a line, select the line (signal) and type a name for the signal like: result[5]. This signal is the bit 5 of the bus result[8..0]. (Sorry for the bad english, i'm brazilian):) Rodrigo Willians- Mark as New
--- Quote Start --- Select the bus and type a name for the bus like: result[8..0] Then, using the Orthogonal Node tool, create a line, select the line (signal) and type a name for the signal like: result[5]. This signal is the bit 5 of the bus result[8..0]. (Sorry for the bad english, i'm brazilian):) Rodrigo Willians --- Quote End --- Thanks buddy! That's what I needed! I, myself am from Iran!
Good and clear.
One principle: always name the wider bus first, then name the narrower bus accordingly. By the way, I am Chinese.- Mark as New
--- Quote Start --- Good and clear. One principle: always name the wider bus first, then name the narrower bus accordingly. By the way, I am Chinese. --- Quote End --- Thankyou !
