公告
17268 討論
How to rectify This error?
Anonymous
不適用
2,013 檢視
I am designing 4-bit comparator using 2-bit comparator and made a circuit .
After running RTL stimulation Error occurs.
I don't know why this error occurs as most of the output is correct but few are wrong.
I attached the screenshot of 2-bit comparator  code and the circuit diagram of 4-bit if you find something wrong then please guide me regarding that issue.
0 積分
4 回應
sstrell
榮譽貢獻者 III
2,004 檢視
You have a typo in your equals logic for the 2-bit comparator.  The first term is using ~A1 when it should be ~B1.
Anonymous
不適用
1,994 檢視
Can you please rephrase and explain what you said?
sstrell
榮譽貢獻者 III
1,991 檢視
Not sure how to rephrase it any clearer.  Your Equal logic assignment should be:
assign Equal = (~A1)&(~A0)&(~B1)&(~B0)....etc.
Anonymous
不適用
1,962 檢視
I made correction in code as you said and now more output are correct but 2-3 are wrong still.
Please Guide me.
回覆
