17268 Discussions
How to report STA (Timing Analysis) just post-Synthesis but before P&R (Placement and Route)?
ldm_as
Hi All,
Is it possible to generate the STA report (e.g. setup violations) just after the Analysis and Synthesis stage? How to?
Is there a way to add a TCL script to Quartus Project, so it will be executed just after the Synthesis stage?
Thank you!
KennyTan_Altera
Hi Dmitry,
You cannot run STA timing analysis after the synthesis stage. Timing analysis need to take the delay for the routing in order to show out the timing result.
You may refer to https://www.youtube.com/watch?v=B73G4BuTpLo to get the understanding on how timing analyzer works,
Kenny
ldm_as
Actually I don't want to proceed to the Fitting stage if there are setup violations presenting already after the Synthesis Stage. Is this possible?
Does not the tool perform any Timing Analysis during Synthesis stage?
sstrell
If you are using the Standard edition of Quartus, you can select to create the timing netlist in the Timing Analyzer based on the post-map netlist (Create Timing Netlist command). If you are using the Pro edition, you have to at least compile to the Plan (or Early Plan) snapshot, which is after synthesis but before the main stages of Place and Route. You can create the timing netlist based off the Plan or Early Plan snapshots.
#iwork4intel
KennyTan_Altera
That is correct. You need the timing/post map netlist to provide you the timing analysis.
ldm_as
How to add scripts, which would be executed after/before a certain stage of Design Compilation Flow?
Let's say I'd like the script_1.tcl would be executed after RTL Analysis & Synthesis, the script_2.tcl would be executed after Fitter stage, and the script_3.tcl would be executed after Timing Analysis stage.
How can I do so?
KennyTan_Altera
Within the scripts, you can use source command to source the scripts out.
ldm_as
You don't understand ... Please read again what I wrote:
Let's say I'd like the script_1.tcl would be executed after RTL Analysis & Synthesis, the script_2.tcl would be executed after Fitter stage, and the script_3.tcl would be executed after Timing Analysis stage. How can I do so?
So, the script_1.tcl, script_2.tcl, and script_3.tcl should be executed in the different stages of the flow. How to do so? In my guess, It should be some attributes in QSF, which would define at what stage each script should be executed.
Thank you!
KennyTan_Altera
Here is the example that you can try:
load_package design
load_package flow
#project_open eight_bit_uc -revision snapshot_test
project_open eight_bit_uc -revision <quartus_project> -force
execute_module -tool syn
source scripts1.tcl
execute_module -tool fit
source scripts1.tc2
execute_module -tool sta
source scripts1.tc3
project_close
Run the scripts with quartus_sh -t <tcl_script>.tcl
Off course there are other method.
ldm_as
I'm about how to integrate the scripts into the GUI/QSF.
Could the PRE_FLOW_SCRIPT_FILE, POST_MODULE_SCRIPT_FILE, POST_FLOW_SCRIPT_FILE attributes be used? How?
KennyTan_Altera
Nope, you can refer to https://www.intel.com/content/www/us/en/programmable/support/support-resources/design-examples/design-software/tcl/auto_processing.html
It is actually the same like the example above by not using GUI. Any reason that you need to use gui to automate the process? Usually, the solution is not using GUI for scripting purposes.
KennyTan_Altera
Any update?
