17252 Discussions
How to report a bug in the Quartus tool?
MoZdk
I previously encountered a bug in the Quartus tool, as described here:
https://forums.intel.com/s/question/0D50P000043ycVOSAY/should-quartus-181-support-ff-creation-by-this-q-d-when-risingedgeclkthe-d-and-clk-are-input-ports-on-a-module-and-q-is-a-output-portthe-quartus-181-breaks-with-internal-error-due-to-this-construction
I have tried to find a way to report this through a support case to Intel, but I am running in circles on the Intel support page, and can't find a way to report this. Trying Quartus => Help => Feedback gives "Our apologies. The page you have requested could not be found. ... HTTP 404"
Can anybody advise me on how to report a bug in the Quartus tool ?
Thanks in advance.
KennyTan_Altera
Is your design.qar file confidential? If not, can you attached over here? can put your crash report here?​
MoZdk
Thanks for attending to this.
"Unfortunately" I am not longer able to recreate the problem in Quartus 18.1.0 Build 625 09/12/2018 SJ Lite Edition, so for some reason my Quartus installation handles the construction now. The problem was originally described in:
https://stackoverflow.com/questions/52622535/difference-between-process-and-vanilla-vhdl/52622723#52622723
where Quartus made the error:
"Internal Error: Sub-system: BPM, File: /quartus/db/bpm/bpm_hard_block_util.cpp, Line: 3458 ... Quartus Prime Information ... Version: 18.1.0 Build: 625 Edition: Lite Edition"
Back when I initially looked into the problem I could recreate the error several times, and it only occurred when the special construction was enabled.
But I have attached the the project that originally caused the problem anyway, in the file "SO_52622535_FF_by_concurrent_assign__Intel.zip".
I consider this issue closed, unless I encounter the problem again.
