17266 Discussions
Ignoring clock skews in set_max_delay constraint
UserQuartus19-3
Hi
I have a clock domain crossing in my design  and I have placed synchronisers at the crossing paths. I have specified the constraint set_max_delay -from [src clk] -to [dest_clk] [time period of src clk] for avoiding timing errors on the crossing paths.
However Quartus is throwing timing errors with huge clock skews between the 2 clocks. I wanted to know how we can specify to ignore the clock path skews in such a scenario.
I have seen related discussions (https://community.intel.com/t5/Programmable-Devices/set-max-delay-vs-set-net-delay/td-p/232670) but couldn't understand any solution out of it.
I am using Arria 10 FPGA and Quartus 19.3 Prime Pro Version.
sstrell
Without looking at your design, if these clock domains are asynchronous, you should use set_clock_groups to simply cut all paths between them.  By using set_max[min]_delay, the tool will still analyze timing on paths that go between these clock domains and you see what's happening.
So simply try this instead of set_max[min]_delay:
set_clock_groups -asynchronous -group src_clock -group dest_clk
If the clock domains are synchronous to each other and you're still getting timing failures, then you may need to look into using multicycles or, better yet, adding registers or using a FIFO to handle the clock crossings.
#iwork4intel
KhaiChein_Y_Intel
Can you share the design.qar for investigation?
KhaiY
UserQuartus19-3
Hi KhaiY
Please find attached .
sstrell
#iwork4intel
KhaiChein_Y_Intel
Have you tried Sstrell's suggestions?
KhaiY
UserQuartus19-3
Yes KhaiY I've cleaned timing using Sstrell's suggestions and my sof file works correctly.
KhaiChein_Y_Intel
Thanks for your updates. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
