Induced delay
Colaborador Distinguido II
3.591 Vistas
I have just started learning how to use VHDL and Quartus and I use it for a Cyclone II FPGA.
I need to write a code , which makes my Output High after a fixed time interval , 60 seconds for example.
Thus I wrote the following code for the same, however it gives me a warning that my Output pins are stuck at VCC and therefore the the Output ( an LED ) , which is ideally supposed to be OFF and glow only after 60 seconds, is always ON.
I also tried using a wait for 60 seconds statement, however that gives me a Wait statement error, saying that at WAIT UNTIL is required.
The code is
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.all;
entity timer is
port ( q : buffer bit := '0');
end entity;
architecture behaviour of timer is
begin
q <= '1' after 60 sec;
end behaviour;
0 kudos
25 Respuestas
2.140 Vistas
Hi shbhuk,
To provide a delay,you need to use the counter.Counter can divide the frequency and you should use the divided frequency to provide delay.The code you have written can work in simulation.But when you synthesize it "after"
keyword will be ignored by the synthesis tool and that is why value of q will remain 1.
Krupesh
2.140 Vistas
Thank you, will work on the frequency divider now then.
2.140 Vistas
For a timer of 20 seconds.
I wrote the following code, however the code still gives me the OUTPUT as always high.
The clock used is 50 MHz ( 20 ns ) and therefore I seek to count till 10^9 to obtain 20 seconds.
Below is the code -
library IEEE;
entity timer is
port ( clk : in std_logic ; q : buffer bit );
end entity;
architecture Behavioral of timer is
begin
process(clk)
variable cnt, cnt1: integer range 0 to 10**9 := 0 ;
constant int: integer := (10**6)+1 ;
begin
if rising_edge(clk) then cnt := (cnt + 1)mod int;
if cnt = 10**6 then cnt1 := (cnt1 + 1) mod 1001;
end if;
end if;
if cnt1 = 1000 then q <= '1' ;
end if ;
end process;
end behavioral;
Please help.
2.140 Vistas
this will be very expensive in hardware, and timing will be rather slow because of use of the mod function (which is essentially a divider)
2.140 Vistas
I will be using an FPGA ( Cyclone II ) , what would you recommend instead ?
The timer works as a timed preset for a counter in turn.
2.140 Vistas
There's no point in using mod function: test when the counter reaches the divider value and then reset it.
if cnt = int
cnt := 0;
else
cnt:= (cnt + 1);
end if;
end if;
Same for cnt1
2.140 Vistas
You can use simple 16 or 32 bit counter and output of this counter can be assigned to your output.For example,we can divide a frequency by 8 using 3 bit counter.You can assign msb of counter to your output which will stay high for four clock cycle and low for four clock cycle.
2.140 Vistas
--- Quote Start ---
--- Quote End ---
The problem with that would be the low frequency I require .
My final time requirement ranges from 30 sec to 30 minutes.
I changed the code to the following , which still gives OUTPUT as always HIGH.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
entity timernew is
port (clk : in std_logic;
flag : out std_logic:='0' );
end timernew;
architecture behavioral of timernew is
begin
process(clk)
variable count : integer:=0;
variable count1: integer:=0;
constant int: integer :=(10**6);
begin
if(clk'event and clk='1') then
count := count +1; --increment counter.
end if;
if count = int then
count := 0;
else
count := count + 1;
end if;
if count1 > 1000 then flag <= '1' ;
end if;
end process;
end behavioral;
2.140 Vistas
I think your count1 variable is not incremented.You should try count instead of count1.
2.140 Vistas
There are 3 major errors:
- You increment count twice and count1 never.
- When count1>1000 you also need to reset count1 to 0 in addition to setting flag output.
- You set flag output but never reset it
2.140 Vistas
I rectified the error.
Now however, when I run the code on the FPGA , even though according to the code the LED should light up after 20 seconds, the LED is lit from the beginning.
2.140 Vistas
The new code is -
library IEEE;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity timernew is
flag : out std_logic := '0' );
end timernew;
architecture Behavioral of timernew is
begin
process(clk)
begin
if count = int then
count := 0;
else
count1 := count1 + 1;
end if;
end if;
end if;
end process;
end Behavioral;
2.140 Vistas
Do the counters create registers? Check the RTL schematic. You have used a variable after updating it, which usually risks the synthesisor not creating a register for it. The best way to avoid this as a beginner is to always use signals, never variables.
2.140 Vistas
I changed the variables to signals, however still the LED glows instantaneously rather than waiting for 20 seconds and glowing.
Is the structure of the IF statements correct ( Nested or not ) .
2.140 Vistas
Try changing
with
else flag <= '0' ;
Did you assign the flag signal to the correct fpga pin?
2.140 Vistas
Changed as asked above.
Also , pin assigned correctly.
Still problem persists.
Please help.
2.140 Vistas
have you got a testbench?
2.140 Vistas
No test bench.
Any idea regarding what could possibly be the source of error ?
2.140 Vistas
How about I use a wait until count = 10**9; ?
2.059 Vistas
You would find the error more easily with a testbench.
Responder
