Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Unable to checkout a license. Vsim is closing.
** Error: Invalid license environment. Application closing.
Hello Firman,
This issue will be supported through private email as some confidential info is required.
Thanks!
Wani
Hi
I am trying to use quartus lite ver21.1 ,when I try to run simulation I get " Invalid license environment
I have downloaded a valide license but still not able to run simulation
Gabi
hi, I have the same problem, help me please
thanks
Hi Wani,
I have the same issue. Do we have a fix for it?
- Rakesh
In my case, ModelSim was not installed (It does not get installed automatically with Quartus 21.1 as it does with older versions). After installing it manually and setting the path in Quartus, the problem disappeared.
- Rakesh
Hi Rakesh,
I've tried looking for the modelsim installer but I can't find it anywhere. Could you help me here?
-Quwam
Hi Quwam,
You can download Modelsim from:
https://fpgasoftware.intel.com/20.1.1/?edition=lite&platform=windows
After installation, you can set the Modelsim path in Quartus (Tools -> Options -> General -> EDA Tools Options).
- Rakesh
Hola tengo un problema al compilar
me aprese el siguiente mensaje
"Error: Invalid license environment. Application closing."
como puedo solucionar esto , ayuda
Hello!
I have the same problem with Quartus on Ubuntu 22.04.
I would be grateful for help!
