17255 Discussions
Max10 ADC simulation in QuestaSim fails to simulate output
twister1398
I'm trying to simulate the Max10 ADC in QuestaSim 2021.3. The ADC Core ready signal (modular_adc_0_command_ready) never goes high. I suspect that the following warning may be related to this behaviour:
Warning: (vsim-PLI-3691) Expected a system task, not a system function '<protected>'.
#    Time: 0 ps  Iteration: 0  Protected: /adc_controller_tb/adc_controller/modular_adc_0/control_internal/adc_inst/adcblock_instance/primitive_instance/inst/<protected>/<protected>/<protected> File: J:/Programme/intelFPGA_lite/18.1/quartus/eda/sim_lib/mentor/fiftyfivenm_atoms_ncrypt.v Line: 38
To me, it looks like QuestaSim can not read the encrytped IP file fiftyfivenm_atoms_ncrypt.v. I did compile the altera libraries for both verilog and vhdl using Quartus Prime 20.1.0 lite and used the 'Run Simulation Tool> RTL Simulation' command of quartus to set up the simulation in QuestaSim.
I attach the log files of the library compilation, as I have noticed that for the file fiftyfivenm_atoms_ncrypt.v, no top level modules are listed. Is this the expected behaviour during library compilation?
Any help is appreciated.
RichardTanSY_Altera
Hi @twister1398
This is normal behavior, if you compile the fiftyfivenm_atoms_ncrypt.v standalone, you can see there are modules listed in the compiled library.
Regarding to ready signal (modular_adc_0_command_ready) never goes high, I would suggest to review your design and testbench.
You may checkout the User Guide below for further information:
https://www.intel.com/content/www/us/en/programmable/documentation/sam1393576011848.html#sam1456148842880
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
RichardTanSY_Altera
Hi @twister1398
Richard Tan
RichardTanSY_Altera
Hi @twister1398
Thank you for the best answer confirmation. I’m glad that your question has been addressed. With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
