17267 Discussions
May I put a structural model inside the process
Hsidd4
Hello everyone,
I have bunch of concurrent statement in different structure module and I need to run them in a sequence. Is there a way to do it.
Like I have multiple instantiation of different module. Most of them consist concurrent statement. I want these module to run one by one. I am using VHDL ( It solution should be implementable on FPGA )
sstrell
It's not clear what you're looking for. Can you post some code?
The closest I can guess from your description is the use of the generate command to control the instantiation of entities.
#iwork4intel
