17268 Discussions
ModelSim Altera Starter Edtion 10.0d - set EndTime
The Simulate - Runtime Option, lets me define a default Run time of say 1us. Then upon Simulate - Start simulation, the view changes, goes to Simulate and The Run Length can be checked, it still is 1us. Upon Run -All, the executed time ends at 10ns, coincidental the cycle time of the simulation.
I somehow wasn't able to find the proper way to set the end time.
Rene
It will stop automatically if there is not more similation to run (eg. your clock has stopped clocking).
Naa. It didn't even start. It stops after 10ns, and I have a cycle time of 10ns.
could it be stuck in an infinite loop?
can you post some source code?
I'm a couple steps further. Indeed the simulation runs until no changes occur. Meaning I have to gate the clock like :
-- Clock Generator
process begin
clock <='0';
wait until Reset = '1';
wait for clockcycle;
while Reset = '1' loop
clock <= '1';
wait for clockcycle/2;
clock <= '0';
end loop;
wait;
end process;
The gate process :
-- Reset
process begin
Reset <= '0';
wait for Clockcycle;
Reset <= '1';
wait for EndOfTime;
Reset <= '0';
wait;
end process;
Otherwise it runs forever. Clearly ignoring my wish with the End Time.
And even stranger, I have to set the stuff up with a reset = 1 otherwise it also runs forever without a result.
-- main
begin
data <= "00000011";
latch <= '1';
cnten <= '1' ;
Reset <= '1'; -- must be 1 here !!!
Now, at least I get a simulation going...
Thanks a lot this far.
you cannot assign reset inside and outside the process. This will cause reset to be 'X'
