I am having this error message when attempting to run the model sim execution in the University Program VWF.
My OS is windows 10, i5 processor. I am running the 23.1 software version. I am using the MAX10 10M50DAF484C7G device (DE10-Lite).
from the reading that have done I need to go to tools, Options, EDA Tool Options, under the model sim tab I need to point it to the correct directory. When I search I have assigned the following directory:
C:/intelFPGA_lite/simulation/modelsim
I get to the modelsim folder and there are no further folders to go into, I have removed and reinstalled the software and I am having the same issue.
What am I missing and how can I fix it?
The directory should be qsim (for Questasim), not modelsim, just as shown in the window. Questasim replaced Modelsim in Quartus about 2 or 3 years ago, so if you're using 23.1, it should be qsim or questasim in the path, not modelsim.
I have attempted to run the simulation the following ways and I am still receiving an error message. Can you explain further what you mean since there is still a persisting error?
You may take a look at below forum as I believe this is how you should specify the path.
I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
