17254 Discussions
ModelSim: no ouput for assert statement
Hallo,
I started to experiment with VHDL simulation and verification lately, so I wrote a testbench and simulated it with ModelSim-Altera 6.e1 Starter Edition. The testbench includes some assert statments but unfortunatly Modelsim doesn't display any errors when this assert statements are executed. I enabled "Enable assertion debug" in the Simulation Properties window and checked the settings in the Runtime Options window.
Can anybody tell me how i get Modelsim to display an error-message when an assert statement is executed?
The testbench can be downloaded here (http://www.stefanvhdl.com/vhdl/vhdl/tb1.vhd) (it's from an online course (http://%3cbr%20/%3e%0ahttp://www.stefanvhdl.com/vhdl/html/basic_stim_gen.html))
Thanks in advance,
magixD
The report part of an assert only occurs if the statement is false. The way I remember it is:
assert (all is good) report "all is not good" severity failure;
I know, I wrote the assert statement so that 'all is not good' ;)
This is the source code again (it's the same as in the link from the first post):
library ieee; use ieee.std_logic_1164.all; use std.textio.all; use ieee.std_logic_arith.all; use work.txt_util.all; entity TB1 is end TB1; architecture test of TB1 is signal x1: std_logic; signal x2: std_logic; signal y: std_logic; begin test_seq: process variable cnt: integer := 0; --*variable slv: std_logic_vector(X2'range); begin x1 <= '0'; x2 <= '0'; wait for 10 ns; x1 <= '1'; x2 <= '0'; wait for 10 ns; x1 <= '0'; x2 <= '1'; wait for 10 ns; x1 <= '1'; x2 <= '1'; wait for 10 ns; assert y = (x1 xor x2) report "E@TB: circuit failed" severity Error; assert y = (x1 xor x2) report "E@TB: failure at: x1="& std_logic'image(x1)& " x2="& std_logic'image(x2) severity Error; assert y = (x1 xor x2) report "E@TB: failure at: x1="& str(x1)& " x2="& str(x2) severity Error; x1 <= 'X'; x2 <= 'X'; wait for 30 ns; x1 <= '1', '0' after 10 ns, '1' after 20 ns, '0' after 30 ns; x2 <= '1', '0' after 20 ns; wait; -- stop process end process test_seq; -- this is supposed to be an xor ... but it isn't y <= (x1 and not x2) or (x2 and not x1) or (x1 and x2); end test;
