PLATFORM DESIGNER
Njoroge
Does Platform Designer in the latest Quartus software, 24.3, have an option to have a custom window-layout?
sstrell
Platform Designer has always allowed you to move, rearrange, minimize, and detach tabs from the main interface.  You can even save your layout as a .layout file from the View menu.
Njoroge
This is the menu from the View tab in Platform Designer. I see no option to save a layout.
sstrell
Scroll down.  There should be a "Custom Layouts" submenu at the very bottom.
Njoroge
That menu cannot be scrolled, unless my 1366x768, 15.6-inch screen is the issue. Even disabling the taskbar doesn't reveal any options below "Reset to BSP Standalone IP Layout Ctrl-4"
sstrell
Increase your resolution. It’s there.
Njoroge
Sorry for the delayed reply. That resolution is as farthest as my hardware allows. Decreasing the font size of Platform Designer to 8 works to show those custom layout options but it's too small to discern anything else like the connections in system view.
ShengN_Intel
May I know does the problem being resolved based on the suggestion?
Sheng
