17245 Discussions
Programming sof into FPGA from command line
MK_ABQ
New Contributor III
I have an intel FPGA devkit with Arria10. I am able to program the FPGA Sof through the quartus programmer GUI. But, when I try to use the command line option, then i get the Error (213013): Programming hardware cable not detected.
Here is the output of my jtagconfig --debug
my devkit is in index 2 and I tried the following command with no luck.
quartus_pgm -c 2 -m jtag -o "p;test.sof@1"
can you help?
MK_ABQ
New Contributor III
removing the remote server connection at index  1 seemed to solve the issue for me.  the following command still worked fine: quartus_pgm -c 1 -m jtag -o "p;test.sof@1"
sstrell
I don't think you're supposed to have the quotes around the -o option.
https://www.intel.com/content/www/us/en/docs/programmable/683039/24-1/scripting-support-08828.html
MK_ABQ
New Contributor III
Fakhrul
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
