17266 Discussions
Project Creation Error in HDL Workflow Advisor
Sawicki
Iam following Mathworks guide on HDL coder. But in HDL Workflow Advisor project creation under Embadded System Integration task that I launch fails.
Failed Create Project.
Task "Create Project" unsuccessful. See log for details.
Generated logfile: C:\Users\user\Documents\MATLAB\hdlv3\hdlsrc\hdlcoder_led_blinking_4bit\workflow_task_CreateProject.log
Info: *******************************************************************
Info: Running Quartus Prime Shell
    Info: Version 19.1.0 Build 670 09/22/2019 SJ Lite Edition
    Info: Copyright (C) 2019  Intel Corporation. All rights reserved.
    Info: Your use of Intel Corporation's design tools, logic functions
    Info: and other software and tools, and any partner logic
    Info: functions, and any output files from any of the foregoing
    Info: (including device programming or simulation files), and any
    Info: associated documentation or information are expressly subject
    Info: to the terms and conditions of the Intel Program License
    Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
    Info: the Intel FPGA IP License Agreement, or other applicable license
    Info: agreement, including, without limitation, that your use is for
    Info: the sole purpose of programming logic devices manufactured by
    Info: Intel and sold by Intel or its authorized distributors.  Please
    Info: refer to the applicable agreement for further details, at
    Info: https://fpgasoftware.intel.com/eula.
    Info: Processing started: Fri Jul 30 12:02:21 2021
Info: Command: quartus_sh -t quartus_create_prj.tcl
Info: Running Quartus Prime Fitter
    Info: Processing started: Fri Jul 30 12:02:25 2021
Info: Command: quartus_fit --read_settings_files=on --write_settings_files=off system -c system --plan
Info: qfit2_default_script.tcl version: #1
Info: Project  = system
Info: Revision = system
Warning (11747): Analysis and Synthesis (quartus_map) with top-level entity name "system" was not run before running I/O Assignment Analysis -- I/O Assignment Analysis will check only I/O assignments on the reserved pins
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines.  Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Info (20030): Parallel compilation is enabled and will use 2 of the 2 processors detected
Info (119006): Selected device 5CSXFC6D6F31C8 for design "system"
Info (21076): High junction temperature operating condition is not set. Assuming a default value of '85'.
Info (21076): Low junction temperature operating condition is not set. Assuming a default value of '0'.
Warning (292013): Feature LogicLock is only available with a valid subscription license. You can purchase a software subscription to gain full access to this feature.
Info (184020): Starting Fitter periphery placement operations
Info (184021): Fitter periphery placement operations ending: elapsed time is 00:00:00
Info (11798): Fitter preparation operations ending: elapsed time is 00:00:16
Info: Quartus Prime I/O Assignment Analysis was successful. 0 errors, 3 warnings
    Info: Peak virtual memory: 5443 megabytes
    Info: Processing ended: Fri Jul 30 12:02:42 2021
    Info: Elapsed time: 00:00:17
    Info: Total CPU time (on all processors): 00:00:18
INFO: Quartus license check was successful.
Info (125061): Changed top-level design entity name to "system_soc"
Info (23030): Evaluation of Tcl script quartus_create_prj.tcl was successful
Info: Quartus Prime Shell was successful. 0 errors, 3 warnings
    Info: Peak virtual memory: 4701 megabytes
    Info: Processing ended: Fri Jul 30 12:02:46 2021
    Info: Elapsed time: 00:00:25
    Info: Total CPU time (on all processors): 00:00:06
Elapsed time is 25.0184 seconds.
2021.07.30.12:02:46 Info: Doing: <b>qsys-script --script=qsys_create_system.tcl</b>
2021.07.30.12:02:52 Info: load_system system_soc.qsys
2021.07.30.12:03:12 Info: set_project_property DEVICE_FAMILY Cyclone V
2021.07.30.12:03:12 Info: set_project_property DEVICE 5CSXFC6D6F31C8
2021.07.30.12:03:22 Info: validate_system
2021.07.30.12:03:22 Info: save_system system_soc.qsys
Elapsed time is 36.4763 seconds.
2021.07.30.12:03:23 Info: Doing: <b>qsys-script --script=qsys_insert_ip.tcl</b>
2021.07.30.12:03:30 Info: load_system system_soc.qsys
2021.07.30.12:03:53 Info: add_instance led_count_ip_0 led_count_ip 1.0
2021.07.30.12:03:53 Info: add_connection pll_0.outclk0 led_count_ip_0.ip_clk
2021.07.30.12:03:53 Info: add_connection hps_0.h2f_reset led_count_ip_0.ip_rst
2021.07.30.12:03:53 Info: set_instance_parameter_value pll_0 gui_output_clock_frequency0 50.000000
2021.07.30.12:03:53 Info: add_connection hps_0.h2f_axi_master led_count_ip_0.s_axi
2021.07.30.12:03:53 Info: set_connection_parameter_value hps_0.h2f_axi_master/led_count_ip_0.s_axi baseAddress 0x0000
2021.07.30.12:03:53 Info: add_connection pll_0.outclk0 led_count_ip_0.axi_clk
2021.07.30.12:03:53 Info: add_connection hps_0.h2f_reset led_count_ip_0.axi_reset
2021.07.30.12:03:53 Info: add_interface led_count_ip_0_GPLED conduit end
2021.07.30.12:03:53 Info: set_interface_property led_count_ip_0_GPLED EXPORT_OF led_count_ip_0.GPLED
2021.07.30.12:03:53 Info: validate_system
2021.07.30.12:03:53 Info: save_system system_soc.qsys
Elapsed time is 30.6205 seconds.
2021.07.30.12:04:26 Info: Saving generation log to C:/Users/user/Documents/MATLAB/hdlv3/quartus_prj/qsys_prj/system_soc/system_soc_generation.rpt
2021.07.30.12:04:26 Info: Starting: <b>Create HDL design files for synthesis</b>
2021.07.30.12:04:26 Info: qsys-generate C:\Users\user\Documents\MATLAB\hdlv3\quartus_prj\qsys_prj\system_soc.qsys --synthesis=VERILOG --output-directory=C:\Users\user\Documents\MATLAB\hdlv3\quartus_prj\qsys_prj\system_soc\synthesis --family="Cyclone V" --part=5CSXFC6D6F31C8
2021.07.30.12:04:26 Info: Loading qsys_prj/system_soc.qsys
2021.07.30.12:04:27 Info: Reading input file
2021.07.30.12:04:27 Info: Adding hps_0 [altera_hps 19.1]
2021.07.30.12:04:27 Info: Parameterizing module hps_0
2021.07.30.12:04:27 Info: Adding led_count_ip_0 [led_count_ip 1.0]
2021.07.30.12:04:27 Info: Parameterizing module led_count_ip_0
2021.07.30.12:04:27 Info: Adding pll_0 [altera_pll 19.1]
2021.07.30.12:04:27 Info: Parameterizing module pll_0
2021.07.30.12:04:27 Info: Building connections
2021.07.30.12:04:27 Info: Parameterizing connections
2021.07.30.12:04:27 Info: Validating
2021.07.30.12:04:38 Info: Done reading input file
2021.07.30.12:04:42 Info: system_soc.hps_0: HPS Main PLL counter settings: n = 0  m = 47
2021.07.30.12:04:42 Info: system_soc.hps_0: HPS peripherial PLL counter settings: n = 0  m = 39
2021.07.30.12:04:42 Info: system_soc.pll_0: The legal reference clock frequency is 5.0 MHz..650.0 MHz
2021.07.30.12:04:42 Info: system_soc.pll_0: Able to implement PLL with user settings
2021.07.30.12:04:46 Info: system_soc: Generating <b>system_soc</b> "<b>system_soc</b>" for QUARTUS_SYNTH
2021.07.30.12:04:52 Info: Interconnect is inserted between master hps_0.h2f_axi_master and slave led_count_ip_0.s_axi because the master is of type axi and the slave is of type axi4.
2021.07.30.12:04:52 Warning: hps_0.f2h_irq0: Cannot connect clock for <b>irq_mapper.sender</b>
2021.07.30.12:04:52 Warning: hps_0.f2h_irq0: Cannot connect reset for <b>irq_mapper.sender</b>
2021.07.30.12:04:52 Warning: hps_0.f2h_irq1: Cannot connect clock for <b>irq_mapper_001.sender</b>
2021.07.30.12:04:52 Warning: hps_0.f2h_irq1: Cannot connect reset for <b>irq_mapper_001.sender</b>
2021.07.30.12:04:57 Info: hps_0: "Running  for module: hps_0"
2021.07.30.12:04:58 Info: hps_0: HPS Main PLL counter settings: n = 0  m = 47
2021.07.30.12:04:59 Info: hps_0: HPS peripherial PLL counter settings: n = 0  m = 39
2021.07.30.12:05:02 Info: hps_0: "<b>system_soc</b>" instantiated <b>altera_hps</b> "<b>hps_0</b>"
2021.07.30.12:05:02 Info: led_count_ip_0: "<b>system_soc</b>" instantiated <b>led_count_ip</b> "<b>led_count_ip_0</b>"
2021.07.30.12:05:02 Info: pll_0: "<b>system_soc</b>" instantiated <b>altera_pll</b> "<b>pll_0</b>"
2021.07.30.12:05:04 Info: mm_interconnect_0: "<b>system_soc</b>" instantiated <b>altera_mm_interconnect</b> "<b>mm_interconnect_0</b>"
2021.07.30.12:05:04 Info: irq_mapper: "<b>system_soc</b>" instantiated <b>altera_irq_mapper</b> "<b>irq_mapper</b>"
2021.07.30.12:05:04 Info: rst_controller: "<b>system_soc</b>" instantiated <b>altera_reset_controller</b> "<b>rst_controller</b>"
2021.07.30.12:05:04 Info: fpga_interfaces: "<b>hps_0</b>" instantiated <b>altera_interface_generator</b> "<b>fpga_interfaces</b>"
2021.07.30.12:05:05 Info: hps_io: "<b>hps_0</b>" instantiated <b>altera_hps_io</b> "<b>hps_io</b>"
2021.07.30.12:05:05 Info: led_count_ip_0_s_axi_translator: "<b>mm_interconnect_0</b>" instantiated <b>altera_merlin_axi_translator</b> "<b>led_count_ip_0_s_axi_translator</b>"
2021.07.30.12:05:30 Error: border: Error during execution of script generate_hps_sdram.tcl: seq: FATAL: Cannot generate IP in a Windows evironment!
2021.07.30.12:05:30 Error: border: Error during execution of script generate_hps_sdram.tcl: seq: An error occurred
2021.07.30.12:05:30 Error: border: Error during execution of script generate_hps_sdram.tcl: Generation stopped, 3 or more modules remaining
2021.07.30.12:05:30 Error: border: Execution of script generate_hps_sdram.tcl failed
2021.07.30.12:05:30 Error: border: ERROR: FATAL: Cannot generate IP in a Windows evironment!
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:06 Info:
2021.07.30.12:05:30 Error: border: ********************************************************************************************************************
2021.07.30.12:05:30 Error: border: Use qsys-generate for a simpler command-line interface for generating IP.
2021.07.30.12:05:30 Error: border: Run ip-generate with switch --remove-qsys-generate-warning to prevent this notice from appearing in subsequent runs.
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:11 Warning: Ignored parameter assignment device=5CSXFC6D6F31C8
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:11 Warning: Ignored parameter assignment extended_family_support=true
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:19 Warning: hps_sdram: 'Quick' simulation modes are NOT timing accurate. Some simulation memory models may issue warnings or errors
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:19 Warning: hps_sdram.seq: This module has no ports or interfaces
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:19 Warning: hps_sdram.p0: p0.scc must be exported, or connected to a matching conduit.
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:19 Warning: hps_sdram.as: as.afi_init_cal_req must be exported, or connected to a matching conduit.
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:19 Warning: hps_sdram.as: as.tracking must be exported, or connected to a matching conduit.
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:19 Warning: hps_sdram.c0: c0.status must be exported, or connected to a matching conduit.
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:19 Warning: hps_sdram.p0: p0.avl must be connected to an Avalon-MM master
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:19 Info: hps_sdram: Generating altera_mem_if_hps_emif "hps_sdram" for QUARTUS_SYNTH
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:21 Info: pll: "hps_sdram" instantiated altera_mem_if_hps_pll "pll"
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:21 Info: p0: Generating clock pair generator
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:22 Info: p0: Generating hps_sdram_p0_altdqdqs
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:30 Info: p0:
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:30 Info: p0: *****************************
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:30 Info: p0: Remember to run the hps_sdram_p0_pin_assignments.tcl
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:30 Info: p0: script after running Synthesis and before Fitting.
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:30 Info: p0: "hps_sdram" instantiated altera_mem_if_ddr3_hard_phy_core "p0"
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:30 Error: seq: FATAL: Cannot generate IP in a Windows evironment!
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:30 Error: seq: An error occurred
2021.07.30.12:05:30 Error: border: while executing
2021.07.30.12:05:30 Error: border: "error "An error occurred""
2021.07.30.12:05:30 Error: border: (procedure "_error" line 8)
2021.07.30.12:05:30 Error: border: invoked from within
2021.07.30.12:05:30 Error: border: "_error "FATAL: Cannot generate IP in a Windows evironment!""
2021.07.30.12:05:30 Error: border: ("if" then script line 2)
2021.07.30.12:05:30 Error: border: "if { $OS_WIN == 1} {
2021.07.30.12:05:30 Error: border: _error "FATAL: Cannot generate IP in a Windows evironment!"
2021.07.30.12:05:30 Error: border: return ""
2021.07.30.12:05:30 Error: border: }"
2021.07.30.12:05:30 Error: border: (procedure "alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer_sw" line 22)
2021.07.30.12:05:30 Error: border: "alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer_sw $prefix $protocol $tmpdir $fileset {} $rdimm $lrdimm $mem_size $mem_size  "${prefix}_sequencer..."
2021.07.30.12:05:30 Error: border: "set return_files_sw [alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer_sw $prefix $protocol $tmpdir $fileset {} $rdimm $lrdimm $mem_size $mem_size ..."
2021.07.30.12:05:30 Error: border: (procedure "generate_sw" line 16)
2021.07.30.12:05:30 Error: border: "generate_sw $name $fileset"
2021.07.30.12:05:30 Error: border: ("if" then script line 4)
2021.07.30.12:05:30 Error: border: "if {[string compare -nocase $fileset QUARTUS_SYNTH] == 0} {
2021.07.30.12:05:30 Error: border: 		set top_level_file "altera_mem_if_hhp_qseq_synth_top.v"
2021.07.30.12:05:30 Error: border: 		add_fileset_file $top_level_fi..."
2021.07.30.12:05:30 Error: border: (procedure "generate_files" line 4)
2021.07.30.12:05:30 Error: border: "generate_files $name QUARTUS_SYNTH"
2021.07.30.12:05:30 Error: border: (procedure "generate_synth" line 3)
2021.07.30.12:05:30 Error: border: "generate_synth altera_mem_if_hhp_qseq_synth_top"
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:30 Info: seq: "hps_sdram" instantiated altera_mem_if_hhp_ddr3_qseq "seq"
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:30 Error: Generation stopped, 3 or more modules remaining
2021.07.30.12:05:30 Error: border: 2021.07.30.12:05:30 Info: hps_sdram: Done "hps_sdram" with 7 modules, 24 files
2021.07.30.12:05:30 Info: border: "<b>hps_io</b>" instantiated <b>altera_interface_generator</b> "<b>border</b>"
2021.07.30.12:05:31 Info: system_soc: Done "<b>system_soc</b>" with 11 modules, 52 files
2021.07.30.12:05:31 Error: qsys-generate failed with exit code 1: 70 Errors, 4 Warnings
2021.07.30.12:05:31 Info: Finished: <b>Create HDL design files for synthesis</b>
Elapsed time is 98.049 seconds.
 I tried changing HDL Code Generation Settings to Verilog instead of VHDL but nothing changed. Iam using Quartus 19.1 and got Cyclone V libraries instaled. OS: Windows 10, Matlab R2021a.
Iam including error log file
Sawicki
Fixed the issue. The solution steps are:
>Using Intel Quartus Prime 19.1 (patched)
>Instaling ubuntu 18.04 LTS and manualy instaling WSL, make and dos2unix (after updating apt package list)
>Enabling WSL in windows control panel
Sawicki
RightSaidFred
have the same issue and like to try this solution. Here can i find this patch and is it posible to use ubuntu 20.04 LTS and wsl2?
