- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
I'm regenerating a hps system with the Platform Designer and receive a couple of errors during execution of script generate_hps_sdram.tcl
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Error during execution of "{C:/intelfpga/19.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Execution of command "{C:/intelfpga/19.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: child process exited abnormally
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: add_fileset_file: No such file C:/Users/__nnn__/AppData/Local/Temp/alt8344_7417580866586908393.dir/0004_seq_gen/hps_AC_ROM.hex
Error: border: Error during execution of script generate_hps_sdram.tcl: Generation stopped, 3 or more modules remaining
Error: border: Execution of script generate_hps_sdram.tcl failed
I am using Microsoft Windows [Version 10.0.18363.720]
Quartus installation: LAST_QUARTUS_VERSION "19.1.0 SP0.02std Standard Edition"
I found literally the same error description here:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2018/error--border--error-during-execution-of-script-generatehpssdram.html
But the work around ist not useable because this is for Linux Operating Systems only. It shouldn't appear on a Windows machine...
Does anyone have had the same problem or maybe has a solution?
Sincerely yours,
Mirco
Ссылка скопирована
- « Предыдущий
- 1
- 2
- Следующий »
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
can you check any of the below able to solve your issue?
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2018/error--s0--error-during-execution-of---c--intelfpga-xx-x-quartus.html?https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd02192013_986.html?
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/emif/2018/error--s0--error-during-execution-of---quartus-installation--nio.html?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I have checked the 3 solutions.
Solution 1 and 3 are literally the same. The linux subsystem wasn't activated. A reboot after closing the dialog brought no change in the behaviour of the Platform Designer...
Solution 2 has been negative, too. Every system variable pointed to the local drive C: The Variable HOMEDRIVE wa snot present, I created it pointing to a local folder on my C: drive.
The error is the same till now.
Sincerely yours,
Mirco
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Does your hps system consist of DDR4 memory? We have similar case reported because of the windows 10 update.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
My hps system is configured to use a DDR3 memory with 400 MHz clock frequency.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Got it. As mention this problem occur is due to the windows upgrade.
The workaround for it would be use another computer with linux OS for generation, or you may send your design for me to generate it for you. You may check your email on this.
Sorry for the inconvenience case,
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hy, I've exactly the same problem,
for me is not possible to use a computer with linux os and also it is not reasonable request you to generate the system for me.
When this problem will be resolved?
Antonio
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Antonio,
Currently, our engineering are focusing on Qpro development as priority. The fix will not be so soon. I will email you on further details.
We are sorry to inform that.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I've exactly the same problem. Is there a solution to this problem now?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
You may check your email regarding this. As mention in the above, the workaround would be use another computer with linux OS for generation, or you may send your design for me to generate it for you. We are sorry for the inconvenience cause.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
is not possible to use a computer with linux os and also it is inconvenient to attached the design.qar here .is there any other solution?
Thank you.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi I am having the same error and do not have access to a linux computer, can you generate this system for me as well?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Can you try out this solution?
Or
2)
Go to check the jtagserver.exe (same path as in the generate log) whether it is enabled in the firewall for all network types, see below:
jtagserver firewall
You may have to click on the 'Change settings' button with a shield icon on it before the firewall rules are editable - they are locked against being changed by software.
You might need to have the admin to do this.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Any update?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Kenny T.
Can we have any update from you? When will we be able to generate a HPS using SDRAM with an Quartus Version greater than 18.1.1 Build 646 04/11/2019 SJ Standard Edition? Till this Version a HPS compilation was working, even running this great Windows 10 (Version 10.0.18363.720).
The jtagserver does not matter because it is the same on both versions installed parallel on this system. And the Windows Subsystem for Linux is deactivated. So please get us a solution!
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I have successfully compiled Qsys using a linux system, sending code to get compiled by someone else is obviously ridiculous. I know this is not ideal but had to find a workaround.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Seems like we have patch for this https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2020/fatal--cannot-generate-ip-in-a-windows-evironment-.html.
The error message reported are similar,
ERROR: Found Error => border: 2019.06.13.20:07:57 Info: p0: "hps_sdram" instantiated altera_mem_if_ddr3_hard_phy_core "p0"
ERROR: Found Error => border: 2019.06.13.20:07:57 Error: seq: Cannot locate the Nios II Command Shell. Nios II SBT must be installed to generate UniPHY IP cores.
ERROR: Found Error => border: 2019.06.13.20:07:57 Error: seq: An error occurred
ERROR: Found Error => border: while executing
ERROR: Found Error => border: "error "An error occurred""
ERROR: Found Error => border: (procedure "_error" line 8)
ERROR: Found Error => border: invoked from within
ERROR: Found Error => border: "_error "Cannot locate the Nios II Command Shell. Nios II SBT must be installed to generate UniPHY IP cores.""
Can you try this patch and let us know the result?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Kenny,
as you might have seen in my first post from March, 23. I already had installed the mentioned patch 0.02std described in your link.
I tried againg to generate the HPS core and it failed in the same way.:
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: add_fileset_file: No such file C:/Users/twesten/AppData/Local/Temp/alt8424_5228789529751528489.dir/0004_seq_gen/hps_AC_ROM.hex
Error: border: 2020.06.11.09:06:54 Info:
Error: border: ********************************************************************************************************************
Error: border:
Error: border: Use qsys-generate for a simpler command-line interface for generating IP.
Error: border:
Error: border: Run ip-generate with switch --remove-qsys-generate-warning to prevent this notice from appearing in subsequent runs.
Error: border:
Error: border: 2020.06.11.09:07:04 Warning: Ignored parameter assignment device=5CSEBA6U23C7
Error: border: 2020.06.11.09:07:04 Warning: Ignored parameter assignment extended_family_support=true
Error: border: 2020.06.11.09:07:17 Warning: hps_sdram: 'Quick' simulation modes are NOT timing accurate. Some simulation memory models may issue warnings or errors
Error: border: 2020.06.11.09:07:17 Warning: hps_sdram.seq: This module has no ports or interfaces
Error: border: 2020.06.11.09:07:17 Warning: hps_sdram.p0: p0.scc must be exported, or connected to a matching conduit.
Error: border: 2020.06.11.09:07:17 Warning: hps_sdram.as: as.afi_init_cal_req must be exported, or connected to a matching conduit.
Error: border: 2020.06.11.09:07:17 Warning: hps_sdram.as: as.tracking must be exported, or connected to a matching conduit.
Error: border: 2020.06.11.09:07:17 Warning: hps_sdram.c0: c0.status must be exported, or connected to a matching conduit.
Error: border: 2020.06.11.09:07:17 Warning: hps_sdram.p0: p0.avl must be connected to an Avalon-MM master
Error: border: 2020.06.11.09:07:17 Info: hps_sdram: Generating altera_mem_if_hps_emif "hps_sdram" for QUARTUS_SYNTH
Error: border: 2020.06.11.09:07:23 Info: pll: "hps_sdram" instantiated altera_mem_if_hps_pll "pll"
Error: border: 2020.06.11.09:07:23 Info: p0: Generating clock pair generator
Error: border: 2020.06.11.09:07:24 Info: p0: Generating hps_sdram_p0_altdqdqs
Error: border: 2020.06.11.09:07:32 Info: p0:
Error: border: 2020.06.11.09:07:32 Info: p0: *****************************
Error: border: 2020.06.11.09:07:32 Info: p0: Remember to run the hps_sdram_p0_pin_assignments.tcl
Error: border: 2020.06.11.09:07:32 Info: p0: script after running Synthesis and before Fitting.
Error: border: 2020.06.11.09:07:32 Info: p0: "hps_sdram" instantiated altera_mem_if_ddr3_hard_phy_core "p0"
Error: border: 2020.06.11.09:07:32 Error: seq: Error during execution of "{C:/intelfpga/19.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Error: border: 2020.06.11.09:07:32 Error: seq: Execution of command "{C:/intelfpga/19.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: border: 2020.06.11.09:07:32 Error: seq: child process exited abnormally
Error: border: 2020.06.11.09:07:32 Error: seq: add_fileset_file: No such file C:/Users/twesten/AppData/Local/Temp/alt8424_5228789529751528489.dir/0004_seq_gen/hps_AC_ROM.hex
Error: border: while executing
Error: border: "add_fileset_file $file_name [::alt_mem_if::util::hwtcl_utils::get_file_type $file_name 0] PATH $file_pathname"
Error: border: ("foreach" body line 4)
Error: border: invoked from within
Error: border: "foreach file_pathname $return_files_sw {
Error: border: _dprint 1 "Preparing to add $file_pathname"
Error: border: set file_name [file tail $file_pathname]
Error: border: add_fileset_file $..."
Error: border: (procedure "generate_sw" line 18)
Error: border: "generate_sw $name $fileset"
Error: border: ("if" then script line 4)
Error: border: "if {[string compare -nocase $fileset QUARTUS_SYNTH] == 0} {
Error: border: set top_level_file "altera_mem_if_hhp_qseq_synth_top.v"
Error: border: add_fileset_file $top_level_fi..."
Error: border: (procedure "generate_files" line 4)
Error: border: "generate_files $name QUARTUS_SYNTH"
Error: border: (procedure "generate_synth" line 3)
Error: border: "generate_synth altera_mem_if_hhp_qseq_synth_top"
Error: border: 2020.06.11.09:07:32 Info: seq: "hps_sdram" instantiated altera_mem_if_hhp_ddr3_qseq "seq"
Error: border: 2020.06.11.09:07:32 Error: Generation stopped, 3 or more modules remaining
Error: border: 2020.06.11.09:07:32 Info: hps_sdram: Done "hps_sdram" with 7 modules, 33 files
Info: border: "hps_io" instantiated altera_interface_generator "border"
Error: Generation stopped, 2 or more modules remaining
Info: hps: Done "hps" with 64 modules, 116 files
Error: qsys-generate failed with exit code 1: 66 Errors, 4 Warnings
Info: Finished: Create HDL design files for synthesis
Yours, Mirco
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Mirco,
Thanks, can you try the below suggestion? It should be working as we have success story from our side. (running win10 release 1809 build 17763)
- uninstalled Ubuntu 18.04 (If you have)
- uninstalled wsl
- re-installed wsl
- downloaded latest Ubuntu 18.04 from Microsoft Shop & installed it
- executed following on Ubuntu shell :
sudo apt-get update
sudo apt install wsl
sudo apt install dos2unix
sudo apt install make
sudo apt-get upgrade
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/wslpath---nios--ii-eds-installation-directory-or-nios-ii-project.html
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
hello Kenny,
does this fix work even for 18.1 std? i was told the cygwin problem is only for 19.1 and above. can you please let me know? I am stuck and need to get this going.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
- « Предыдущий
- 1
- 2
- Следующий »
