17261 Discussions
Qsys component creation
I am migrating an existing project from SOPC to QSYS and I have some problems with the component editor of QSYS.
In my old SOPC system, my custom components where defined as .ptf files. So I need to generate .tcl files instead in order to be able to use them in QSYS.
What I did is the following:
1/ open the component editor in QSYS
2/ HDL files tab: add the .hdl file of my component in order to have all the required signals in the signals tab
3/ remove the .hdl file
4/ I have then the signals that you see on the attached picture "SignalsPicture.jpg"
5/ HDL Parameters tab: the problem now is that I have "conduit" signals which I did not expect attached to my bloc when I take a look at the preview of the GUI (see "PreviewGUI.jpg").
Is there a way to remove those signals?
I also noticed that these ones are not present when I generate the component without removing the .hdl file in the "HDL files" tab.
How is that so?
i don't quite understand why you are removing the HDL files, but have you tried the Remove Interfaces With No Signals button on the Interfaces tab?
--- Quote Start ---
--- Quote End ---
yes, but these signals do not appear in the "interfaces tab", only when the component is generated.
I really do not understand from where these clk_reset1, avalon_slave_01 and avalon_slave_0_irq1 come from.
It is strange because I can't see these signal in the .tcl file.
# TCL File Generated by Component Editor 11.0# Wed Jun 08 19:14:38 CEST 2011# DO NOT MODIFY # +-----------------------------------# | # | ccd_ctrl "ccd_ctrl" v1.0.1# | null 2011.06.08.19:14:38# | # | # | # | # +----------------------------------- # +-----------------------------------# | request TCL package from ACDS 11.0# | package require -exact sopc 11.0# | # +----------------------------------- # +-----------------------------------# | module ccd_ctrl# | set_module_property NAME ccd_ctrl set_module_property VERSION 1.0.1 set_module_property INTERNAL false set_module_property OPAQUE_ADDRESS_MAP true set_module_property GROUP "Unknown Group" set_module_property DISPLAY_NAME ccd_ctrl set_module_property TOP_LEVEL_HDL_FILE "" set_module_property TOP_LEVEL_HDL_MODULE "" set_module_property INSTANTIATE_IN_SYSTEM_MODULE false set_module_property EDITABLE false set_module_property ANALYZE_HDL TRUE set_module_property STATIC_TOP_LEVEL_MODULE_NAME "" set_module_property FIX_110_VIP_PATH false# | # +----------------------------------- # +-----------------------------------# | files# | # | # +----------------------------------- # +-----------------------------------# | parameters# | # | # +----------------------------------- # +-----------------------------------# | display items# | # | # +----------------------------------- # +-----------------------------------# | connection point clk# | add_interface clk clock end set_interface_property clk clockRate 0 set_interface_property clk ENABLED true add_interface_port clk clk clk Input 1# | # +----------------------------------- # +-----------------------------------# | connection point clk_reset# | add_interface clk_reset reset end set_interface_property clk_reset associatedClock clk set_interface_property clk_reset synchronousEdges DEASSERT set_interface_property clk_reset ENABLED true add_interface_port clk_reset reset reset Input 1# | # +----------------------------------- # +-----------------------------------# | connection point avalon_slave_0# | add_interface avalon_slave_0 avalon end set_interface_property avalon_slave_0 addressAlignment DYNAMIC set_interface_property avalon_slave_0 addressUnits WORDS set_interface_property avalon_slave_0 associatedClock clk set_interface_property avalon_slave_0 associatedReset clk_reset set_interface_property avalon_slave_0 burstOnBurstBoundariesOnly false set_interface_property avalon_slave_0 explicitAddressSpan 32 set_interface_property avalon_slave_0 holdTime 0 set_interface_property avalon_slave_0 isMemoryDevice true set_interface_property avalon_slave_0 isNonVolatileStorage false set_interface_property avalon_slave_0 linewrapBursts false set_interface_property avalon_slave_0 maximumPendingReadTransactions 0 set_interface_property avalon_slave_0 printableDevice false set_interface_property avalon_slave_0 readLatency 0 set_interface_property avalon_slave_0 readWaitTime 1 set_interface_property avalon_slave_0 setupTime 0 set_interface_property avalon_slave_0 timingUnits Cycles set_interface_property avalon_slave_0 writeWaitStates 1 set_interface_property avalon_slave_0 writeWaitTime 1 set_interface_property avalon_slave_0 ENABLED true add_interface_port avalon_slave_0 chipselect chipselect Input 1 add_interface_port avalon_slave_0 read read Input 1 add_interface_port avalon_slave_0 write write Input 1 add_interface_port avalon_slave_0 address address Input 3 add_interface_port avalon_slave_0 writedata writedata Input 32 add_interface_port avalon_slave_0 readdata readdata Output 32# | # +----------------------------------- # +-----------------------------------# | connection point avalon_slave_0_irq# | add_interface avalon_slave_0_irq interrupt end set_interface_property avalon_slave_0_irq associatedAddressablePoint avalon_slave_0 set_interface_property avalon_slave_0_irq associatedClock clk set_interface_property avalon_slave_0_irq associatedReset clk_reset set_interface_property avalon_slave_0_irq ENABLED true add_interface_port avalon_slave_0_irq irq irq Output 1# | # +-----------------------------------
I haven't seen this happen before but you could try refreshing the component library to see if that helps.
Also if you have a working component in SOPC Builder you shouldn't have to recreate the component in Qsys, it should migrate in most cases.
If this continues please file a service request here so that Qsys engineering team can take a look and correct this: http://www.altera.com/mysupport
--- Quote Start ---
--- Quote End ---
All the components are .ptf files (classic components) which do not work with QSYS
--- Quote Start ---
--- Quote End ---
In Qsys? You mean with F5?
It did not help.
--- Quote Start ---
--- Quote End ---
To speed up the compilation process.
