17255 Discussions
Qsys fails with strange error messages never seen before
gyuunyuu
Here is the screen shot:
I have attached text file containing the dump. I am not sure why this error has occurred.
sstrell
At first I thought it was the issue that WSL is now required for the Nios command shell, but you are using 18.1, so it can't be that.  Maybe: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2020/error--execution-of-command----quartusinstallation--nios2eds-nio.html?wapkw=nios%20command%20shell%20wsl
Nurina
Hi, did the above comment help?
gyuunyuu
This Qsys system has generated fine in the past so I am not sure what happened. I shall try out the fix and let you know.
Nurina
Nurina
We did not receive any response to the previous question/reply/answer provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
