17249 讨论
Quartus Assembler error(internal error)
名誉分销商 II
3,612 次查看
Hello,all
I recently synthesis DDR2 controller(my own design) with ALT_DQDQS(quartus generate DQDQS PHY with DDR2_SDRAM). Quartus encounter a Internal error when assembler process. This error is shown as follows picture.
Can you help me to solve this problem ,thank you very much.
http://b29.photo.store.qq.com/http_imgload.cgi?/rurl4_b=e72e028073496c5b726f222663e2631660aa79c72b6cf822d673b5b94bd52664e4cf2df2465e1be691549455cf67104adf4b373c3bb35bae9dbf3a85ba8adc6ae067a33877c9682fcd79f3f99b39b5987623010d&a=28&b=29
0 项奖励
11 回复数
名誉分销商 II
1,950 次查看
You're attached image does not contain the error.
Jake
0 项奖励
名誉分销商 II
1,950 次查看
I don't know how to display this image. I just attach the image address,you can click this address to see the image.
Actually, I can't capture the data by signaltapII which is output from ALT_DQDQS Megafunction, even this data is registered through many registers. Quartus come up a Internal error when assembler process when I capture the data from ALT_DQDQS or I output the data to output port,contrary,quartus assemler run successfully.
Thank you.
0 项奖励
名誉分销商 II
1,950 次查看
PS : I have get into the datapath and look at the write and read registers before they are latched to/from the I/O.
I don't why my controller internal registers can't be probed by SignalTapII??
Is there some another configuration to ALT_DQDQS megafunction,I already read the ALT_DQDQS specification in detail ,but I don't find any information can help me??
0 项奖励
名誉分销商 II
1,949 次查看
Close Quartus and all other programs currently running. Then start Quartus again and begin to compile. If it works now or even it succeded more than before your RAM size is not enough.
0 项奖励
名誉分销商 II
1,949 次查看
I don't think this is memory issue.
Once I probe the data in my data path,this internal error come up even I just run the single process of quartus9.0(Windows Xp),otherwise it runs successfully.
I think it maybe ALT_DQDQS is not correctly configured,but I don't how to debug this problem. I had resarch the ALT_DQDQS SPEC in detail,but don't find any usefull information to solve this problem.
0 项奖励
名誉分销商 II
1,949 次查看
0 项奖励
名誉分销商 II
1,949 次查看
Whether this is io_config problem.
0 项奖励
名誉分销商 II
1,949 次查看
It´s hard to say. I often had some internal errors and then I always compiled it a second or third time and then it works. Thats why I thought of some memory problems. Maybe there are some kind of recursive implementation that make these problems.
0 项奖励
名誉分销商 II
1,949 次查看
i have the same problem, have you solve it?
0 项奖励
回复
