Quartus II v.11.0
Help, please.
When I try to compile some project using QUARTUS II v.11.0 or v.10.01 (web edition bouth) i get these messages:
Info: You have a valid up-to-date license
Error: Selected feature of TimeQuest Timing Analyzer is not available with your current license, or license does not exist
Error: Current module quartus_asm ended unexpectedly
Error: Quartus II Full Compilation was unsuccessful. 2 errors, 0 warnings
I use Wwindows xp sp3, with hardware which meets QUARTUS requirements (512 Mb of Ram)
There was no errors during installation process, I have tied to download License file and use it, to reinstall program, to install fresh coppy of windows and than QUARTUS... nothing helps.
I know that there is more threads on this subject, but there is no solution, so I ask again. I
Apologize for my English.
i've seen this on the forum before, but i'm not sure if it was resolved. have you taken a look?
I read these (two or three) posts and did not help me. Any other idea ?
can you start a new project for scratch and target a recent device (CIII or CIV)? just run a small design like a counter and see if it runs all the way through compilation
I have tried that and still getting same messages:
that's really strange
you said you're using Web Edition and a license file. can you try the counter test project without any license assigned to Quartus?
Tried to work without license file, messages are same.
have you tried to delete all subdirectories (e.g. "db", "incremental_db",..) and start a recompilation (deleting the subdir forces a complete recompile...)
Give it a try..
Carlhermann
-I have made new project and tried to compile it, and I have got errors, so it is a complete recompilation.
-I am trying to enable "Talk back" function, but I dont know what is FAE (field application engineer) username, or where to get it.
-Btw, now I use version 9.1 and it works without errors, but I would like to find solution for problems with newer versions...
Well - can you post the Archieved projekt as it's easier to play around and post the answer than doing wild guesses...
Sincerely, Carlhermann
Where can I find software release notes for quartus ii version 11.0? Now I can find quartus ii version 10.1 sp1 software release notes only. Even in page quartus ii subscription edition.
I ASK AGAIN:
What is FAE (field application engineer) username, and where to get it (need it for Talk back function)???
I have uploaded some simple project which cannot be compiled by my Quartus.
Konst: the QII Release Notes are normally delayed from the software release by a couple of weeks
bosandzeros: if you don't work with an FAE you don't need to fill out that field. if you do you can just ask your FAE
i don't think this is the root cause of your problem
i am able to compile your design successfully with QII 11.0 64-bit Subscription Edition on Windows 7
Even I can compile that project on my PC with QUARTUS v9.1, but i would like to find solution for problem with newer versions.
Any other ideas?
I compiled it OK with Quartus II Web Edition 11.0:
Total combinational functions 25 / 5,136 ( < 1 % ) Flow Status Successful - Sat Aug 13 23:26:26 2011
Dedicated logic registers 14 / 5,136 ( < 1 % ) Quartus II Version 11.0 Build 157 04/27/2011 SJ Web Edition
Revision Name Led_Blink
Top-level Entity Name Led_Blink
Family Cyclone III
Total logic elements 25 / 5,136 ( < 1 % )
Total registers 14
Total pins 2 / 183 ( 1 % )
Total virtual pins 0
Total memory bits 0 / 423,936 ( 0 % )
Embedded Multiplier 9-bit elements 0 / 46 ( 0 % )
Total PLLs 1 / 2 ( 50 % )
Device EP3C5F256C6
Timing Models Final
I know that you can compile it, problem is because I can't do it... So what could be problem with my program?
There can't be anything wrong with your code, if I can compile it. You must have a problem with your Quartus II installation.
I KNOW THAT PROBLEM IS IN QUARTUS II, but I don't have solution for QUARTUS II problem!!!
