15884 Discussions
Quartus Prime Avalon SDRAM Controller - readdatavalid never asserting
albertsun
I'm currently using the DE2-115 education board and implementing the SDRAM controller. When instantiating a read (from the Avalon MM documentation, I believe read requests are pipelined), the readdatavalid signal from the controller is never asserted even when read is asserted. I have tried both leaving the address and read asserted, and de-asserting the read signal after one clock cycle. I believe all the controller ports are connected properly, but I can't be 100% sure since I don't have access to a simulator. Thanks to everyone in advance.
AdzimZM_Intel
Hi Sir,
Do you see the waitrequest signal has been asserted after the read signal been asserted?
Do you see any difference when using burst operation?
I can assist you on Simulator (Modelsim) to simulate the design if you want.
But I need the design file and maybe some instructions.
Adzim
AdzimZM_Intel
I'm hope you're doing well.
May I have any update on this case?
Adzim
albertsun
Apologies for taking awhile to respond. Since the time of posting, I've transitioned to using M9K blocks instead for memory since the application doesn't have a high memory capacity requirement. I've attached a relevant snippet from my wrapper around the SDRAM controller - if that looks good, then there might've been some stray X's within a few signals.
Thanks for all the help again.
AdzimZM_Intel
I'm glad to hear from you. Thanks for your update.
I think the wrapper looks okay.
Please let me know if you have further question on this topic.
Adzim
AdzimZM_Intel
We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
