Avisos
17268 Discusiones
Quartus SDC file: how to specify a register source for a multi path statement ?
MNeum14
Principiante
2.308 Vistas
I have a larger hirachical design, under the help from the 'technology Map Viewer' I created
(the following command in a single line) >>
set_multicycle_path -nocase -from [get_registers {la_control:la_control_1|rg_*}] -rise_to [get_clocks {pll_60_100_200MHz:Pll_1|altpll:altpll_component|_clk1}] 3
the result
Error (332000): invalid command name "get_parents_location" while executing
"unknown_original get_parents_location" ...
I am fighting the 2nd day, tried get_nets , optipon -nocase and and and. I am realla stucked. And I have to fix this problem. What are I doing wrong??
0 kudos
7 Respuestas
sstrell
Colaborador Distinguido III
2.200 Vistas
The error doesn't seem to match or apply to the SDC command you've posted. When do you see this error? Compiling the design or running timing analysis?
The multicycle command itself looks fine to me, though you probably need to add a -setup or -hold to it depending on which analysis you're applying the multicycle to.
#iwork4intel
MNeum14
Principiante
2.200 Vistas
thanks for the response. I get this error when I compile the design and this error is related to this single line, whenever I comment this one out, everything is fine (however timequest reports time violations). I expect a stupid syntay error - but what I am doing wrong?
And yes, I agree, the multicycle command needs to get improved - but first I have solve this error...
MNeum14
Principiante
2.200 Vistas
the problem is within >>-from [get_registers {la_control:la_control_1|rg_*}]<<
I replaced it for a test with a top_level signal >>-from [get_registers {mem_wr_p*}] << and it works Ok
to summarize the involved File structure:
Top entity file               LA_FPGA.vhd
there instantiated       la_control_1 : ENTITY work.la_control
file                           la_control.vhd
with registers               rg_ch_select
(candidates for            rg_trg_mode
 multicycle)                  rg_clk_cntl
                               rg_status_1
                               rg_status_2
                               rg_trg_cntl
                               rg_trg_ref
                               rg_trg_snapshot
                               rg_trg_state
MNeum14
Principiante
2.200 Vistas
In the Quartus Netlist Viewer I see such a register as >>  |La_FPGA|la_control:la_control_1|la_clock:la_clock_1|rg_clk_cntl[26]
MNeum14
Principiante
2.200 Vistas
ooops, in the previous post I picked a wrong example, a correct one is
|La_FPGA|la_control:la_control_1|rg_ch_select[15]
MNeum14
Principiante
2.200 Vistas
Problem solved with the TimeQuest Tool
I was not aware that the Timequest Timing AlalyzerTool offers sdc file reneration including constraints settins. What did I wrong ? - hard to tell, the working result however is
set_multicycle_path -setup -end -from [get_registers -nocase {la_control:la_control_1|rg_*}] -to [get_clocks {pll_60_100_200MHz:Pll_1|altpll:altpll_component|_clk1}] 3
-nocase seems to be on the wrong spot ...
KhaiChein_Y_Intel
Empleados
2.200 Vistas
Thanks for the update. I believe your update is beneficial to other users who have the same problem.
Responder
