17259 Discussions
Quartus prime system console blank window
Mahim
I need to use quartus prime in the linux remote computer to test a board in the lab. When I open quartus pro-> tools-> system console, the window opens and stays blanked. My fellow team mates don't have the same issue even though they use it in the same machine. No matter what I do, the system console window always opens as blanked. In my windows machine, there is no problem, its only when I try to open it in the linux system remotely. But others don't have the issue. What could be the possible reasons?
AndrewG_Intel
Hello @Mahim
We understand that you have some inquiries regarding Intel® Quartus® Prime Software.
We have a forum for those specific products and questions so we are moving it to the Intel® Quartus® Prime Software Forum so it can get answered more quickly.
Andrew G.
SyafieqS
Hi Mahim,
Can you try and launch system console via below method:
1. Starting System Console from Qsys
Click Platform Designer > Tools > System Console.
2. Starting System Console from Nios II Command Shell
On the terminal Type the following command:
system-console
Note: Make sure you have setup the environment variable for nios2eds
QUARTUSDIRECTORY\20.3\...\nios2eds
Let me know if this works
SyafieqS
We do not receive any response from you to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
