17252 토론
Reg: Use ip-generate in Intel Quartus Pro When i use ip-generate in Intel Quartus Pro, it gives error as "ip-generate is not recognized as an internal or external command" But the same command works for Quartus Standard version.
VGopa7
초급자
3,515 조회수
What is the equivalent command used in Quartus Pro ?
Below is the command and the error log:
C:\intelFPGA_pro\19.2\quartus\sopc_builder\bin>ip-generate --output-dir=. --file-set=QUARTUS_SYNTH --component-name=altera_fp_functions --component-param=gen_enable=true --component-param=report_resources_to_xml=1 --system-info=DEVICE_FAMILY="Arria 10" --component-param=fp_format=double --component-param=function_family=ALL --component-param=ALL_function=MUL --output-name=alterafpf_mul_double --component-param=performance_goal=frequency --component-param=frequency_target=200
'ip-generate' is not recognized as an internal or external command,
operable program or batch file.
0 포인트
9 응답
sstrell
명예로운 기여자 III
3,298 조회수
I think in Pro it's quartus_ipgenerate or qsys-script:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-platform-designer.pdf
#iwork4intel
0 포인트
AnandRaj_S_Intel
3,298 조회수
Hi Venu,
The quartus_ipgenerate <project name > [options] command allows you to generate IP components or a Platform Designer system in your Intel Quartus Prime project.
Refer section 6.9 in user guide.
Anand
0 포인트
VGopa7
초급자
3,298 조회수
Hi Anand,
I just want to generate the ip file (.ip file) in the specified location.
The "ip-generate" is used to generate the IP variation file (.ip file) in the specified location in Quartus Prime
But the same doesn't work for Quartus Pro.
I think the "ip-generate" is replaced with some other command in Intel Quartus Pro,
I observed that the "ip-generate" is not present in the installation folder of Quartus Pro.
What is the equivalent command used in Intel Quartus Pro ?
Venu
0 포인트
AnandRaj_S_Intel
3,298 조회수
Hi Venu,
use "quartus_ipgenerate" for Quartus pro.
please go through the previous two posts.
Anand
0 포인트
VGopa7
초급자
3,298 조회수
Hi Anand,
I was referring to this command "ip-generate" to generate an IP using the script from the command line interface, Below is the link which works for Quartus Standard
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd12182013_862.html
I need the equivalent command for the Intel Quartus Pro.
The "quartus_ipgenerate" does not work in Quartus Pro
Venu
0 포인트
AnandRaj_S_Intel
3,298 조회수
​Hi Venu,
The qsys-script and qsys-generate utilities to define and generate an IP core using Tcl script
For command-line use below command.
ip-deploy --output-directory=C:\Users\anand\Desktop\test --component-name=altera_iopll --output-name=pll --family="Cyclone 10 GX" --part=10CX220YF672E6G --component-param=gui_reference_clock_frequency="100" --component-param=gui_output_clock_frequency0="500" --component-param=gui_phase_shift0="0" --component-param=gui_duty_cycle0="50"
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
0 포인트
VGopa7
초급자
3,298 조회수
Hi Anand,
Thank you for your reply, I want to know the list of auguments that can be provided with the "ip-deploy" command.
Also, i see that the argument "file-set" is not working in "ip-deploy" command. Is there any equivalent argument for "file-set" used in "ip-deploy" ?
Below is the "ip-generate" command with arguments: (The underlined argument)
Can you provide the complete list of arguments used for "ip-deploy" ?
0 포인트
AnandRaj_S_Intel
3,298 조회수
Hi Venu,
For list of arguments run ip-generate -h
  1. IP-deploy is used to generate the .ip file after generation of .ip file you can use quartus_ipgenerate for generating synthesis and simulation file.
Run below command and check.
ip-deploy --component-name=altera_iopll --output-name=pll --family="Cyclone 10 GX" --part=10CX220YF672E6G --component-param=gui_reference_clock_frequency="100" --component-param=gui_output_clock_frequency0="500" --component-param=gui_phase_shift0="0" --component-param=gui_duty_cycle0="50"
quartus_ipgenerate --generate_ip_file --synthesis=vhdl --simulation=verilog --clear_ip_generation_dirs --ip_file=pll.ip pll
Anand
0 포인트
AnandRaj_S_Intel
3,298 조회수
Hi Venu,
Any update,
Let me know if the previous post has helped resolve the issue you are facing or if you need any further assistance.
Anand
0 포인트
응답
