- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Anybody has experience running Quartus Standard Edition under a VMware workstation? I used the Lite/free/web edition without any problem. But never tried the licensed edition. Does the license manager work ok?
Lien copié
3 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I've used fixed license with no problems. If your network setup in the VM works and you can get to the license server, you shouldn't have any issues.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thanks. But not quite sure I understand. Are you using a fixed or a floating license? If it is fixed, why do you need a remote license server at all? Shouldn't be able to run the license server locally on the VM?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I'm using fixed, but I have used floating in the past. I've never run the license server on the same machine, though.
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
