17261 Discussions
Signaltap protocol
leonardo_forum
Do you know if is possible to extend Signaltap with custom protocol analyzers (ex. I2C, SPI, etc..)?
Thank you
sstrell
Signal Tap just taps signals.  It's not designed for that.  A better option is using System Console toolkits.  What exactly do you want to see?
leonardo_forum
I would like to create a plugin or something that decode the data on some protocols, for example:
sstrell
You can create mneumonic tables in Signal Tap, but those are meant to decode "parallel" signals (i.e. the seven separate signals that make up a 7-segment display) as opposed to decoding serialized data like what you show here.  Signal Tap can't do that.  It only looks at captured data one clock cycle/sample at a time.
leonardo_forum
Got it. Anyway would be very good to have something more extendible in a future release
SyafieqS
Leonardo,
Let me know if there is any other concern on this.
leonardo_forum
Mine was an imporvement suggestion, hope was appreciated and will be implemented sooner or later
Leonardo
SyafieqS
We do not receive any response from you to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
