17267 Discussions
SystemVerilog logic type as bidir
I'm new to SystemVerilog and have a question about a warning Quartus is throwing. I'm working with a design done by someone else.
In my code I have a 2 interfaces which have port type logic. In the module there is assignment of one logic type to another... for example
interface typeA();
logic[3:0][3:0] mem_A;
endinterface
interface typeB();
logic[3:0] b1;
logic[3:0] b2;
logic[3:0] b3;
endinterface
module dut(typeA in, typeB out);
assign out.b1[0] = in.mem_A[0];
assign out.b2[1] = in.mem_A[1];
assign out.b3[2] = in.mem_A[2];
endmodule
I'm trying to get rid of this warning but don't know what do to since the interfaces are being used multiple times all over the design.
Warning (10665): Bidirectional port "IN.pix[0][2]" at If.sv(47) has a one-way connection to bidirectional port "OUT.grn[0][2]"
Thanks in advance.
The error message has the identifiers 'pix' and 'grn', but they do not exist in the source code.
--- Quote Start ---
--- Quote End ---
The code is just an example...the warning is copied from Quartus. In all correctness the warning to match example should have been
Warning (10665): Bidirectional port "in.mem_A[0][0]" at If.sv(#) has a one-way connection to bidirectional port "out.b1[0][0]"
Warning (10665): Bidirectional port "in.mem_A[0][1]" at If.sv(#) has a one-way connection to bidirectional port "out.b1[0][1]"
Warning (10665): Bidirectional port "in.mem_A[0][2]" at If.sv(#) has a one-way connection to bidirectional port "out.b1[0][2]"
--- Quote Start ---
interface typeA();
endinterface
interface typeB();
logic[3:0] b1;
logic[3:0] b2;
logic[3:0] b3;
endinterface
endmodule.
--- Quote End ---
Don`t you think that, here you are trying to access one interface members by another interface since an interface is a bundle of nets or variables & interface construct in system verilog was specifically created to encapsulate the communication between blocks or modules.
Refer the attached pdf. for detail about an interface.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
