17268 Discussions
SystemVerilog static variables
PElm
I have a problem with local variables in SystemVerilog/Quartus.
static seems not to be working as expected. The following code generates no output(led constant).
always @(posedge clk) begin : P_1us
    static logic [5:0] nClk = 6'd0;
    led <= 1'b0;
    if( nClk == 50 ) begin
         led <= 1'b1;
         nClk = 0;
    end
    nClk++;
end
However removing "static" it works.
With competing tools(Vivado and more) this work as expected.
It seems static is treated as automatic.
sstrell
What version/edition of Quartus are you using?
PElm
@sstrell
I'm using 20.1.1 Build 720
Patches Installed: 1.02i
sstrell
Is that Standard or Pro?
PElm
sstrell
Lite has limited SystemVerilog support.  Maybe that's what you're running into.  Are there any warnings when you compile?
PElm
Does any Altera/Intel staff read this?
Or how do I report errors in Quartus?
RichardTanSY_Altera
Hi @PElm
You may find the warning messages/ error in the Message GUI at the bottom of the Quartus.
As mentioned here: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf
Quartus lite/standard has limited supported in System Verilog. I would recommend to run in Quartus Pro or to change to Verilog language.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
RichardTanSY_Altera
I have yet to receive any response from you to the previous question/reply/answer that I have provided but I believed that I have answered your question.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
