17255 Discussions
Unable to regenerate BSP in Eclipse NIOS II EDS
Contributeur émérite II
8 004 Visites
I recently made a project in the NIOS II EDS version 11.1.
In eclipse I made a BSP and an application to run with the BSP.
Everything worked fine many times, but for some unknown reason, when i want to build, I get this error:
**** Build of configuration Nios II for project rts_experiment **** make all Info: Building ../rts_experiment_bsp/ make --no-print-directory -C ../rts_experiment_bsp/ Makefile not up to date. ../../swsched.sopcinfo has been modified since the BSP was generated. Generate the BSP to update the Makefile, and then build again. To generate from Eclipse: 1. Right-click the BSP project. 2. In the Nios II Menu, click Generate BSP. To generate from the command line: nios2-bsp-generate-files --settings=<settings file> --bsp-dir=<target bsp files directory> make: *** Error 1 make: *** Error 2
However, the BSP project seems to be broken, since if i right-click it, I dont get the generate BSP option in the menu :((((
I made a picture but I can't upload it since i first need 5 posts :S. Its truly not in the right-click menu anymore while it used to be there all the time :(.
This is really annoying me for a few days now, since I have to do the whole create new BSP wizards EVERY TIME i make an adjustment to my system.
I also can't use the command line command in windows, dunno if its supposed to work under windows at all.
I'd be much obliged if someone could help me!
0 Compliments
6 Réponses
6 036 Visites
I had the same issue, but only reinstall of Eclipse helped then.
0 Compliments
6 036 Visites
I have found out that the nios2-bsp-generate-files executable is in (for default location):
C:\altera\11.1sp1\nios2eds\sdk2\bin
If you go there on the command line in windows, you can type:
nios2-bsp-generate-files.exe --settings=<path to bsp folder>\settings.bsp --bsp-dir=<path to bsp folder>
For me it was for example:
C:\altera\11.1sp1\nios2eds\sdk2\bin>nios2-bsp-generate-files.exe --settings=C:\rts\rts_jwp_2011\hw\software\rts_experiment_bsp\set tings.bsp --bsp-dir=C:\rts\rts_jwp_2011\hw\software\rts_experiment_bsp
Then it will indeed generate the bsp manually again like it says in the help text of the error.
Won't have to reinstall eclipse!
bryancitu
Débutant
5 573 Visites
in my case, I did something similar, the difference is that I have version 18.1
C:\intelFPGA_lite\18.1\nios2eds\sdk2\bin>nios2-bsp-generate-files --settings=C:\Users\Bryan\Documents\UNI\Microcontroladores\tutorial3\software\lights_bsp\settings.bsp --bsp-dir=C:\Users\Bryan\Documents\UNI\Microcontroladores\tutorial3\software\lights_bsp
INFO: Generating BSP files...
INFO: nios2-bsp-generate-files --settings C:\Users\Bryan\Documents\UNI\Microcontroladores\tutorial3\software\lights_bsp\settings.bsp --bsp-dir C:\Users\Bryan\Documents\UNI\Microcontroladores\tutorial3\software\lights_bsp
INFO: Initializing BSP components...
INFO: Finished initializing BSP components. Total time taken = 4 seconds
INFO: Searching for BSP components with category: os_software_element
INFO: Initializing SOPC project local software IP
INFO: [Info] <b>C:/Users/Bryan/Documents/UNI/Microcontroladores/tutorial3/*</b> matched 31 files in 0,05 seconds
INFO: [Info] <b>C:/Users/Bryan/Documents/UNI/Microcontroladores/tutorial3/*/*_sw.tcl</b> matched 0 files in 0,01 seconds
INFO: [Info] <b>C:/Users/Bryan/Documents/UNI/Microcontroladores/tutorial3/ip/**/*_sw.tcl</b> matched 0 files in 0,00 seconds
INFO: [Info] <b>C:/Users/Bryan/Documents/UNI/Microcontroladores/ip/**/*_sw.tcl</b> matched 0 files in 0,00 seconds
INFO: Finished initializing SOPC project local software IP. Total time taken = 2 seconds
INFO: Searching for BSP components with category: driver_element
INFO: Searching for BSP components with category: software_package_element
INFO: No memory regions found in BSP Settings File. Default memory regions generated.
INFO: Loading drivers from ensemble report.
INFO: Finished loading drivers from ensemble report.
INFO: Generating BSP files in "C:\Users\Bryan\Documents\UNI\Microcontroladores\tutorial3\software\lights_bsp"
INFO: Default memory regions will not be persisted in BSP Settings File.
INFO: Generated file "C:\Users\Bryan\Documents\UNI\Microcontroladores\tutorial3\software\lights_bsp\settings.bsp"
INFO: Generated file "C:\Users\Bryan\Documents\UNI\Microcontroladores\tutorial3\software\lights_bsp\summary.html"
INFO: Generated file "C:\Users\Bryan\Documents\UNI\Microcontroladores\tutorial3\software\lights_bsp\public.mk"
INFO: Generated file "C:\Users\Bryan\Documents\UNI\Microcontroladores\tutorial3\software\lights_bsp\mem_init.mk"
INFO: Generated file "C:\Users\Bryan\Documents\UNI\Microcontroladores\tutorial3\software\lights_bsp\Makefile"
INFO: Finished generating BSP files. Total time taken = 2 seconds
INFO: BSP files generated in "C:\Users\Bryan\Documents\UNI\Microcontroladores\tutorial3\software\lights_bsp"
and then you can build without problem
0 Compliments
6 036 Visites
Hi, could someone maybe clarify the solution above for me. I don't fully understand what do with the path-specification mentioned. In my simple mindedness I tried typing the entire thing in the windows command line ("run"-box), using the path to my own project directory of course... A black console appeared doing its thing briefly, so maybe I did it right... just don't know because it did not work...
I'm working on a restricted faculty computer though, so maybe that's the problem. Reinstalling the program is really not possible either... A truly frustrating annoyance that the program simply can't remember where it created the project, when it all seems rather spelled out for it...
0 Compliments
6 036 Visites
--- Quote Start ---
--- Quote End ---
regenerate a new BSP by right clicking on the bsp project and then go to nios II and generate bsp and then run your program as a hardware.
0 Compliments
6 036 Visites
Hii I am doing a simple project in Quartus of hello world using NIOS. The issue I am facing is this error message,
[ Description Resource Path Location Type
make: *** [../proj_nios_bsp/-recurs-make-lib] Error -1073741511 proj_nios C/C++ Problem]
Please help me out!!!! I am not able to find any solution.
0 Compliments
Répondre
