17252 토론
Unconstrained record support Quartus Prime Standard 23.1 VHDL-2008
Capricorn
초급자
1,095 조회수
I have an  array of an unconstrained record:
  type PinCtrlCfg is
  record
    PinMuxSelect            : std_logic_vector;
    EnableOutput            : std_logic;
  end record;
  type PinCtrlCfgArray is array (natural range <>) of PinCtrlCfg;
 I'm trying to use it like this:
signal Cfg : PinCtrlCfgArray(NUM_OUTPUTS_G-1 downto 0)(PinMuxSelect(toLog2Ceil(NUM_INPUTS_G)-1 downto 0));
 This works fine in Questa. However, when trying to synthesize in Quartus, I get the following error message:  "object "PinMuxSelect" is used but not declared"
VHDL-2008 support is enabled.
Unconstrained arrays work fine, but are unconstrained records not supported in Quartus? I'm using Prime Standard 23.1.
레이블 (1)
3 응답
ShengN_Intel
직원
1,047 조회수
Questa is testbench based so there's different between the synthesis behavior of the Questa and Quartus. Some of the code Questa can compile but Quartus can't. You may try with other compiler tool and should get the same result.
In VHDL, you cannot access or index into a record field like PinMuxSelect in the signal declaration. The signal declaration must refer to the entire record or array, not individual fields.
For example appropriate one:
signal Cfg : PinCtrlCfgArray(NUM_OUTPUTS_G-1 downto 0);
for i in 0 to NUM_OUTPUTS_G-1 loop
    Cfg(i).PinMuxSelect <= std_logic_vector(to_unsigned(i, Cfg(i).PinMuxSelect'length));
end loop;
0 포인트
Capricorn
초급자
1,024 조회수
Hi
This is not what I'm trying to do. I'm specifying the size of PinMuxSelect, which is not constrained in the record.
Here is a simplified example:
signal Cfg : PinCtrlCfgArray(3 downto 0)(PinMuxSelect(7 downto 0));
This is part of VHDL-2008 .
0 포인트
ShengN_Intel
직원
1,015 조회수
I had tried with other compiler tool and get the same synthesis error. That's not supported in synthesis tool.
Sheng
0 포인트
응답
