17245 Discussions
Using constants from package on bdf
dsmirnov
There were some questions on this forum about constants on  *.bdf, e.g. https://community.intel.com/t5/Intel-Quartus-Prime-Software/Is-a-Quartus-bdf-file-can-access-a-package-in-WORK-library/m-p/134534
The main problem is that if I would like to use *.bdf as my top-level file and I would like to have the ability to change some parameters I use generic/parameter to make it appear on top-level.
Imagine  I would use vhd-file as top-level. I can write such code:
library work;
entity process_test is
    generic (
        CCC : INTEGER := work.my_pack.myPar
where my_pack is a package with constant myPar defined. During compilation, Quartus will create a proper scheme with the value of CCC equal to the value of myPar from the package.
While using *.bdf-file I can try to use the same approach:
But while compiling it gets an error.
I can't truly understand why it doesn't see my constants, because it definitely uses work library. However, I can't use any package with constants so they can be assigned to these parameters. Notice, whenever I generate *.vhd-file from any good *.bdf I see one important line:
library work;
which tells me that this file must get all information from work.
Of course, I can use the solution with set_parameter (https://community.intel.com/t5/Intel-Quartus-Prime-Software/Block-Diagram-File-with-Parameters-Generate-VHDL-File-not/td-p/17001) but it doesn't really well for modelling in Modelsim plus it keeps constants only for top-level file, so with deep hierarchy, I can't set values for deep files.
Now, the question: is it normal behaviour for *.bdf? Why does it see work library but still doesn't see constants from work? Is there any way to add package on *.bdf?
RichardTanSY_Altera
Have you tried the KDB below?  You can try to use the param primitives and constant primitives.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd06082010_663.html
What is the error shown during the compilation?
dsmirnov
Dear @RichardTanSY_Altera,
Thank you for your answer. Yes, I tried this solution, but it is uncomfortable:
- it is a graphical info which I can't store in a separate file
- It is hard to keep in git
- I can't use same constant in different layers of files - I have to duplicate this param inside of another bdf
The error from the option I showed on image in my question is:
Error (275082): Illegal values "work.my_pack.myPar" for parameter "CCC". The type is "Signed Integer".
I guess that means that the compiler doesn't see my constant myPar from the package my_pack
RichardTanSY_Altera
Could you share your design and package so that I could duplicate it from my side?
dsmirnov
Yes @RichardTanSY_Altera , the project attached to this message
RichardTanSY_Altera
Sorry for idling for sometime. The BDF is weak in handling this kind of situation.
My best bet is to write the design in VHDL in the first place.
