Ankündigungen
17268 Diskussionen
VHDL code P2, Is anybody who can help me ?
Geehrter Beitragender II
1.965Aufrufe
Hi guys,
I have some code for this "project" (photo). I have no idea hot to pair this. Can You help me with port map and signals ? This code is correct ?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity projekt is
port(Up,Down, : in std_logic;
A0, A1, A2, A3: out std_logic);
end projekt;
architecture projekt of projekt is
begin
s1 <= up
s2 <=
entity component is
port (T: in std_logic
Clock: in std_logic
Out: out std_logic);
signal tmp: std_logic;
end component;
Architecture Behavioral of component is
begin
process (Clock)
begin
if Clock'event and Clock='1' then
if T='0' then
tmp <= tmp;
elsif T='1' then
tmp <= not (tmp);
end if;
end if;
end process;
Out <= tmp;
end przerzutnik;
begin
T_FF: T1 port map(T
T_FF: T2 port map
T_FF: T3 port map
T_FF: T4 port map
6 Antworten
1.230Aufrufe
You appear to be missing all the port maps, plus I assume a copy paste error as the code is a little odd (there is a begin after the end)
Please re-post correct code and state what problems you're having
1.230Aufrufe
--- Quote Start ---
--- Quote End ---
I replicated only code for T flip-flop. Succession is not important bcs i know hot to sort this code. I don't know how to attribute signals and where they must be. Any suggestions?
1.230Aufrufe
What do you mean by "attribute signal"?
The code is full of syntax errors and incomplete. So without a reasonable code example, and a specific problem, it is hard to understand what you want....
1.230Aufrufe
--- Quote Start ---
--- Quote End ---
My teacher said : Later, you declare a component for the main unit, signals to connections, components and porting mapping ( with no logic describing how works flip flop)
I know its uncomplete but want to know how it works, what is it ? And maybe i wll find code in the internet,I need it now rly, I don't asking for much, only to help with that.
1.230Aufrufe
The template is something like
<libraries> entity name_of_module is <generic and port lists> end entity; architecture name_of_architecture of name_of_entity is <all aliases, signals components and constants> begin <processes, signal assignments, port maps etc> end architecture;
a generic/port map looks like
label : name_of_component generic map( some_gen => 0 ) port map ( clk => higher_level_clock );
1.230Aufrufe
--- Quote Start ---
--- Quote End ---
Finally good reply:) Thank You o much !
Antworten
