17267 Discussions
VHDL code P2, Is anybody who can help me ?
Hi guys,
I have some code for this "project" (photo). I have no idea hot to pair this. Can You help me with port map and signals ? This code is correct ?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity projekt is
port(Up,Down, : in std_logic;
A0, A1, A2, A3: out std_logic);
end projekt;
architecture projekt of projekt is
begin
s1 <= up
s2 <=
entity component is
port (T: in std_logic
Clock: in std_logic
Out: out std_logic);
signal tmp: std_logic;
end component;
Architecture Behavioral of component is
begin
process (Clock)
begin
if Clock'event and Clock='1' then
if T='0' then
tmp <= tmp;
elsif T='1' then
tmp <= not (tmp);
end if;
end if;
end process;
Out <= tmp;
end przerzutnik;
begin
T_FF: T1 port map(T
T_FF: T2 port map
T_FF: T3 port map
T_FF: T4 port map
You appear to be missing all the port maps, plus I assume a copy paste error as the code is a little odd (there is a begin after the end)
Please re-post correct code and state what problems you're having
--- Quote Start ---
--- Quote End ---
I replicated only code for T flip-flop. Succession is not important bcs i know hot to sort this code. I don't know how to attribute signals and where they must be. Any suggestions?
What do you mean by "attribute signal"?
The code is full of syntax errors and incomplete. So without a reasonable code example, and a specific problem, it is hard to understand what you want....
--- Quote Start ---
--- Quote End ---
My teacher said : Later, you declare a component for the main unit, signals to connections, components and porting mapping ( with no logic describing how works flip flop)
I know its uncomplete but want to know how it works, what is it ? And maybe i wll find code in the internet,I need it now rly, I don't asking for much, only to help with that.
The template is something like
<libraries> entity name_of_module is <generic and port lists> end entity; architecture name_of_architecture of name_of_entity is <all aliases, signals components and constants> begin <processes, signal assignments, port maps etc> end architecture;
a generic/port map looks like
label : name_of_component generic map( some_gen => 0 ) port map ( clk => higher_level_clock );
--- Quote Start ---
--- Quote End ---
Finally good reply:) Thank You o much !
