17260 Discussions
When I try to make and run University Program VWF, it gives this error :"ModelSim executable not found" .
FGECE
As a solution, it says that: "To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both ModelSim-Altera and ModelSim executables are available, ModelSim-Altera will be used."
First I have searched and found that i should have “C:\altera\13.1\modelsim_ase\win32aloem\” this file direction and file in my computer but there is no such file and I have reinstalled the program. Still it has same problem.
What can I do for that problem? Thanks...
sstrell
So what directory have you installed ModelSim-Altera edition? Point Quartus to that location (the win32aloem directory).
#iwork4intel
Vicky1
In addition to the previous post, please check the below old thread & let me know how it works for you,
https://forums.intel.com/s/question/0D50P00003yyQA2SAM/cant-launch-the-modelsimaltera-software?language=en_US
Vicky
russesho
russesho
If you installed it in :
C:\altera\13.1_web
you need to go to options => EDA Tool Options and under ModelSim-Altera enter:
C:\altera\13.1_web\modelsim_ase\win32aloem
Essentially you need to add \modelsim_ase\win32aloem to the install location.
Vicky1
May I know any update or shall I consider to be case closed?
-Vicky
