17265 Discussions
Why I cannot edit the GPIO Lite Intel FPGA IP in Quartus 18.1?
IElha
this is the log error message i got when tried to edit the gpio lite intel fpga using quartus 18.1 and MAX 10 device
Megafunction GPIO Lite Intel FPGA IP v18.1 is not listed in any
wizard.lst file in the specified library path(s).Wizard launch aborted
SreekumarR_G_Intel
Hello , Is the log file attached ? Sorry I couldn't find , Can you copy and paste in the forum ? Thank you , Regards, Sree
IElha
Hi All,
I put it here in case someone will face the same issue.
You should add the next line "<ALIAS>GPIO Lite Intel FPGA IP v18.1</ALIAS>"
to altera_gpio_lite_wizard.lst file.
This file is located at \\intelFPGA\18.1\ip\altera\altera_gpio_lite\
SreekumarR_G_Intel
Thank you , Can you please close the case ? Regards, Sree
SreekumarR_G_Intel
