- Running both Quartus 18.0 and 18.1 (both lite) on Windows 10 - when I start the wizard clearbox.exe popups up a stopped working. The wizard UI runs through but isn't generating the files correctly after exiting the wizard. Any suggestions?
Hello I am facing exactly (!) the same problem. I am using a "DE2-115" board together with the "Quartus 18.1.1 Build 646 SJ Lite Edition" on a "Win8.1prof" installation.
Has a solution to this been found in the meantime?
A reinstallation solved the problem (... before that uninstall and delete all remaining registry keys and file relics).
Hi Vikas,
Cyclone V (5CSEBA6U23I7)
Dave
Hi Dave,
I tried to replicate your issue but I couldn`t replicate, please refer screenshot.
Can you check with different IPs?
Vikas
Hi Dave,
Actually I tried with Q16.1, Q18.0 & Q18.1 Lite that too different-different machines but I haven`t come across the issue you are facing.
Could you please help me to check at your end with different machine?
I will also check in parallel with Q19.1 Lite, if possible you can also check with latest version.
thanks,
Vikas
Hi Dave,
Can we get any update by using different machine? if possible to you..
or should I consider to be close this case?
Vikas
Hi Vikas,
I have access to another Windows 10 machine today - I'll try it on that.
Kind regards,
Dave
Hi Dave,
Any update..
Vikas
Hi Dave,
It seems that "clearbox.exe" issue is with your specific machine and it might be due to Quartus temporary files so I would suggest you to take backup first & then remove the below suggested files,
Must take backup of all files first & keep it at different place/device
Perform the below steps,
1.Create a backup of following files located at “C:\Users\<user name>”
- quartus2.qreg
- quartus2.ini
- Remove these two files first, and then try re-launching Quartus
2.If the problem still persists please try same with “.altera.quartus” file located in same directory.
please update me , how it works for you.
Vikas
Hi Dave,
May I know any update..
Vikas
Hi Dave,
Any update..
Vikas
Hi Vikas,
I deleted all the files you suggested and the problem persists on my machine
Kind regards,
Dave
