17261 Diskussionen
alias of pin assignment
NuvKFC
Neuer Beitragender I
1.457Aufrufe
I have a pin_assign.csv file.
Unfortunately, the pins name in the pin_assign.csv file are too complex.
Can I set some alias or some command in the pin_assign.csv file?
Thank you very much.
1 Lösung
SyafieqS
Mitarbeiter
1.397Aufrufe
Hi KF Cc,
I did not read you question properly.
Assuming I understand it correctly, I don't think yes because Quartus will use the exact pin names according to the csv when you import it. Assigning an alias will lead to unknown pin assignment as Quartus not able to detect it.
Lösung in ursprünglichem Beitrag anzeigen
7 Antworten
SyafieqS
Mitarbeiter
1.429Aufrufe
KF C,
Are you referring to what command function?
You can use a assignment to import assignment of the csv file list of your pins
SyafieqS
Mitarbeiter
1.419Aufrufe
Hi KF Cc,
May I know if there is any update from my previous reply
NuvKFC
1.409Aufrufe
Hi SyafieqS
    Thank you, SyafieqS, very much. Sorry that I forgot this questions.
What is command function?
I use the CSV file imported method to assign pin location like following picture. Does there have command function?
SyafieqS
Mitarbeiter
1.398Aufrufe
Hi KF Cc,
NuvKFC
1.390Aufrufe
Hi SyafieqS
I want to add alias into CSV file because the pad name is too complex.
From your answer, this requirement can't be met.
I get it.
SyafieqS
Mitarbeiter
1.376Aufrufe
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
NuvKFC
1.354Aufrufe
Hi SyafieqS
    Theank you, SyafieqS, very much. Ok.
Antworten
