17268 Discussions
assigned a pin to ground
Hi everyone,
I have a max10 FPGA and I want to assigned a pin to the gnd
Because my circuit is like this:
output pin(3.3V ) LED power supplied(3.3V)
so If I want to light up my LED, I should have an output pin=0V. I've try some VHDL code, it seems it doesn't work
library ieee;
use ieee.std_logic_1164.all;
ENTITY et IS
PORT(
s : out std_logic );
END et ;
ARCHITECTURE data_flow OF et IS
BEGIN
s<= '0';
END data_flow;
I've also tried null instead of 0. But it still doesn't work. is it because I don't have IN std_logic
thank you in advance
Did you assign s port to the correct device pin?
thank you for ur replying. Yes I did and i'm sure about that
--- Quote Start ---
--- Quote End ---
What is the value of your current limiting resistor? Did you put a scope or a meter to measure the output pin?
Kevin Jennings
--- Quote Start ---
--- Quote End ---
Null would be incorrect, '0' is correct.
--- Quote Start ---
--- Quote End ---
No
Kevin Jennings
The pins can source and drain the required current? I would reccommend using a ground pin. I think there must be a couple of those.
Thank you for your replying,
I couldn't really measure the current, now. Because I work in a starting project. But it was an experimented engineer, who develop that board. So I think he should think about that.
I thought it may be have problem of compatibility of USB blaster II, which is not compatible with Altera max10 or the frequency of Jtag, 6MHz instead of 24MHz, but I don't know how to change that frequency
Ok, thank you
--- Quote Start ---
Kevin Jennings
--- Quote End ---
--- Quote Start ---
--- Quote End ---
Thank you for replying, I couldn't use a ground pin. Because I have to manage light up or light down the LED.
Could I just connect the ground directly to an output in schematic, does it work?
well, you need to complete the circuit, so it should work, assuming the output can drive enough current.
